Best sc300 Exhaust
If you're looking for performance and style, I highly recommend a near OEM replacement. Check out the double offset Magnaflows: http://www.magnaflow.com/02product/s...ne=main&id=350
If the muffler shop is any good, they'll cut the tips off the OEM muffler and put them on the Magnaflows. The mufflers also have a slightly smaller profile which I like, and they're designed as a straight through muffer (i.e. no baffles). It will look better than stock and won't change the sound of your car at all. I can't tell you how many guys I've smoked because the sound of the car didn't give anything away.
Considering the OEM mufflers have pushed 585rwhp with no midpipe cat (Lex Luthor's VVT-i sp63 sc300), the Magnflows should be good to 600+ hp.
-scott
-scott
Originally Posted by CleanSC
You have the Nur Spec on your SC and it selts off alarms? I can barely hear mine. Are you running an otherwise stock exhaust? Still got your resonators, cats, small pipes, etc, etc?
