Ticking sound coming from engine - please help
Old 07-04-05, 01:31 AM
Lexarse
Lexarse's Avatar
Default Tick tick
hi... this question is for the machanical minded... i have a sc400 and its got a tick in the engine.. its not there when u start it but you can hear it after a few seconds.. then it gose after a drive at 100 kays plus.. but returnsonce you drivearound town.l. any help on stoping this would be awsome
Old 07-04-05, 05:06 AM
hayaku
hayaku's Avatar
If the ticking is constant it could be the lifters.
Old 07-04-05, 09:20 AM
Dx3
Dx3's Avatar
Exactly what I was about to say
Jonny
Old 07-04-05, 10:10 AM
jgscott
jgscott's Avatar
Received 1,323 Likes on 1,052 Posts
When was the last time you changed the oil. ?
Old 07-07-05, 12:40 AM
Lexarse
Lexarse's Avatar
i changed the oil about 500 kays ago and its still there the old oil was black as all hell and had bits in it....i was thinking that maybe from sitting so long some crap had build up on the lifters and such... i was told that maybe one of the oil holes in the lifts (if there is such a thing) may be cloged with this crap.. i put some oi cleaning stuff in the egine b4 we changed it done about 500 kays with that in the oil.. it helped a little.. im thinking i should do it again...
if it is the lifter what can i do to fix it
cheers
Old 07-07-05, 01:12 PM
sonyman
sonyman's Avatar
I have heard with the SC400 at least, you need to change the valve shims to fix the ticking. It isn't a cheap job either. It is $300-400 for parts alone. That is why mine ticks and probably will for a while. However, you can try using a heavier weight oil, or a thick additive like Valvoline SynPower and see if it helps at all. Right now I am using M1 EP 5W-30, which is very thin, and therefore my ticking is very audible.
Scott
Old 07-11-05, 05:43 PM
Spyder187
Spyder187's Avatar
Hmm... Those Hydrolic Tappered (?) lifters will cause a tick to occur when the car has been sitting for some time. After driving it for quite a while, the ticking should eventually go away. Please correct me if I'm wrong...
Old 07-11-05, 06:50 PM
jgscott
jgscott's Avatar
I would change that oil again with Moble 1 or some synthic oil. If it had that much stuff in it. Its not all out. And drive it like someone said. You using the Lexus Toyota filter ?
LexorG
01-09-17 10:02 PM
songlou
01-07-16 02:14 PM
tea
08-18-15 10:22 PM
sagarx
11-03-09 10:23 AM
Quick Reply: Ticking sound coming from engine - please help
