uh turbo time NA-T feed me!
#151
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
My fellow sc300 enthusiasts, here are the best shipped prices I found for ARP headstuds and a supra TT headgasket. If you find them cheaper, pls post in this thread.
ARP Head Studs: $125 www.competitionwarehouseusa.com
Supra TT headgasket: $92.43 www.carjunky.com
Total: $217.43
Total: $217.43
#152
1UZFE/2JZGTE
Total: $217.43
Total: $217.43
Damn those are excellent prices thanks.
#153
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
What do you all think of this muffler?
http://www.magnaflow.com/02product/s...ne=main&id=617
I can get these for ~$67 shipped to your doorstep EACH. If this company follows through properly, I'll post link here, but they have to prove themselves first
. Planning to order 2 of them tomorrow
#155
Originally Posted by chidoks
good luck with the project
New Problem: Timing belt keeps skipping gear teeth on the cam wheels after the car is revved and it tries to settle into idle.
The Timing Belt tensioner has been changed as well as idler pulling and timing belt itself.
This is a stock 2JZ-GE engine. Nothing on it has been change..i.e cam wheels are stock, etc. The only mods are the DaveH manifold + turbo parts that are installed.
Has anyone ever experienced this before? This needs to be figured out before the project can continue and thicker headgket can be installed
#156
I could sure use some "wisdom" from all of you car enthusiasts at this point. They got the car running at the shop..turns out I didn't bolt that ecu bolt all the way in, so ecu wasn't getting powered = no spark.
. Any help from all of you would be greatly appreciated.
#158
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
Originally Posted by MadMaxxNA
Hmmm..
1) they are using the correct belt?
2) All the teath on the cam gears intact?
3) Belt tension is good?
#159
try double checking the tensioner. doesnt mean you got a new but defective unit. check to see if there is oil or grease on the gears, then finally recheck the belt. thats all i can think of right now
#161
technicians called me back and referenced Toyota's service books confirming that it IS possible for the valves to hit the cylinder, thus making the engine an "interference engine" able to bend valves! wth?
#162
technicians called me back and referenced Toyota's service books confirming that it IS possible for the valves to hit the cylinder, thus making the engine an "interference engine" able to bend valves! wth? ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
#163
After removing the timing belt, exhaust cam wheel moves fine, but the Intake cam wheel does not move fine at all...after taking the intake valve cover gasket off, it looks like the intake cam cover was damaged. The 2nd picture you see of it is after a technician at Toyota filed it out with some sand paper type material. Although he thought it would be wiser to just get a new head. How did it get damaged?
Perhaps some abrasive particle came out of the turbo and made its way up into that small oil hole on the cam and destroyed the groove?
![](http://i19.photobucket.com/albums/b188/dejacky/IntakeCamcover1.jpg)
![](http://i19.photobucket.com/albums/b188/dejacky/IntakeCamcover2.jpg)
#164
where the cams removed ever? if so what were they torqued at when put back on and was a lubricant used in the process? im thinking either your theory of something getting in there to do that or else the cap was torqued too tight and had a lack of oil at somepoint in time and just destroyed itself.
