uh turbo time NA-T feed me!
#212
Originally Posted by lsflame
any updates? let me know I am so into this install. I have been following it since the first day. I love your setup and wish you luck!!
* When replacing the NA pump with a supra TT fuel pump, you MUST bypass the main fuel relay switch, thereby providing a constant 12 volt voltage to the pump. Dinosaur performance discovered this problem since the car would not get proper fuel when the throttle was applied more than a "little bit." The symptom was the engine would shut off when you pressed the throttle more than a little. Giving the fuel pump a constant voltage fixed it . For more info, look here:
http://www.mkiv.com/techarticles/12v_mod/12v_mod.htm
Old eye candy (BOV is on, just not in these pics):
#216
Originally Posted by shaman
DId you rewire the pump? Several people have gotten better power out of the Fuel Pump with a relayed wire from the battery.
#217
Originally Posted by dejacky
what do you mean by "rewire?"
Running a thicker wire directly off the battery to the fuel pump
http://www.zzperformance.com/grand_p...ts1.php?id=177
#219
Originally Posted by SPORTcoupe
Hope you get your clutch done soon and can fully enjoy the final product.
#222
Originally Posted by mikevanle
Remove the cruise control, charcoal canister, polish and clean up some stuff, and it'll look real nice
