uh turbo time NA-T feed me!
Old 07-24-05, 03:55 PM
dejacky
dejacky's Avatar
Those are 550cc RX7 injectors that are ported to flow 605cc . They are a "drop in" replacement for the stock 2JZ-GE injectors.
Old 07-24-05, 10:41 PM
laxdude362
laxdude362's Avatar
Nice SMIC. Where did you get it? And how much?
Old 07-25-05, 03:23 AM
dejacky
dejacky's Avatar
supraforums.com. How much? pls don't give me a headache .
Old 07-25-05, 09:17 AM
SUPRMSC
SUPRMSC's Avatar
Looking very nice! Make sure to check all the welds on the Daveh manifold, as it has been used before.
One concern though, you're using a small turbo for a 400 rwhp application.. Are you planning to swap the turbo out later on?
Old 07-25-05, 10:43 AM
dejacky
dejacky's Avatar
Thumbs up
no,
I want a wide and "streetable" powerband thats why i chose the TE44. I might just settle for 310-350rwhp on stock compression at 10psi with retarded timing and no headgasket mod. this should be plenty fun . btw, what should I look for when looking at the welds? They seem fine to me from a visual inspection .
This is my idea of the final setup. Please correct me if I'm wrong folks:
Btw, will this small hole for the screw hole cause any problems?:
Old 08-06-05, 11:04 AM
dejacky
dejacky's Avatar
Thumbs up
DaveH manifold and wastegate dump pipe sand blasted and hot-jet ceramic coated with techtrex 2000 degree temperature rating:
Old 08-06-05, 11:28 AM
kaotiq
kaotiq's Avatar
Do you plan on redoing the downpipe and some of that exhaust piping? It looks like it is in real bad shape
Old 08-06-05, 12:16 PM
dejacky
dejacky's Avatar
Thumbs up
I plan to cut and use the mandrel bent DaveH shorty downpipe & midpipe. They are welded to the Crush bent piping that has narrow passages throughout the exhaust. I don't plan on using any of this restricting crush-bent piping. Instead, I want to keep the exhaust piping full mandrel 3inch diameter until the dual collector, where I thought dual 2.5 inch piping is appropriate. The type of ceramic used on this manifold and wastegate dump pipe WILL chip if sharp objects hit it hard...so I need to find a different type of ceramic coating for the exhaust system that won't chip since it's under the car OR heatwrap the ceramic coated exhaust system since the ceramic coating protects the pipe from rust and corrosion.
Current Ceramic Coating Ideas:
Exhaust
Turbine Exhaust housing
Old 08-06-05, 01:10 PM
kaotiq
kaotiq's Avatar
I'm glad that you are getting rid of that piping. Hey how much was your jet hot coat for the exhaust mani?
Old 08-06-05, 01:31 PM
dejacky
dejacky's Avatar
Thumbs up
I can probably do a Club Lexus member special for ~$140 if you're really interested. That price includes sand blasting + the coating itself & my time for inspection and delivery service. The guy that does this for me is very experienced and local to me.
Old 08-06-05, 02:18 PM
mikevanle
mikevanle's Avatar
How much did you pay for the Rx7 injectors if you don't mind me asking. I guess it was used and not cleaned?
Old 08-06-05, 02:24 PM
kaotiq
kaotiq's Avatar
Originally Posted by dejacky
I can probably do a Club Lexus member special for ~$140 if you're really interested. That price includes sand blasting + the coating itself. The guy that does this for me is very experienced and local to me.
Well, I don't think that my manifold needs sandblasting. I believe the GReddy turbo kits come with stainless steel? (Not sure) I just need to have it hi-temp coated. Would it be cheaper without blasting?
Old 08-06-05, 03:22 PM
got_trd
got_trd's Avatar
looking good...... now stop staring at it and get a car to put it in
Old 08-06-05, 03:24 PM
ATL-SC
ATL-SC's Avatar
hey love to see some one doing a set up witha real budget with a resonable power goal. my friend just got done with his budget honda and now ive got the need for boost. so im starting to plan for next summer. keep up the good work and all the posts. cant wait to see the finished product.
Old 08-06-05, 05:28 PM
Last5Spd
Last5Spd's Avatar
Damn thats a sexy Manifold
Quick Reply: uh turbo time NA-T feed me!
