uh turbo time NA-T feed me!
#122
Oh no! The "supra TT fuel pump" upgrade is not as plug and play as a I thought
. What did you all do to make it fit the stock NA clip? This is from a 1995 Lexus SC300 5 speed. Help from you more experienced folks would be much appreciated since my car HAS to be running in a few hours :fingersx: .
Stock NA Fuel pump = LEFT. Supra TT fuel pump = RIGHT.
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
![](http://i19.photobucket.com/albums/b188/dejacky/FuelPumpInstall5.jpg)
#124
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
No Fear. I have an easy solution
. Basically, you add 2 stainless steel hose clamps with a sliced fuel hose between the metal bracket and fuel pump to keep everything secure. In the middle of the process it should look like this:
![](http://i19.photobucket.com/albums/b188/dejacky/FuelPumpReinstall2.jpg)
Here is the BEFORE:
![](http://i19.photobucket.com/albums/b188/dejacky/FuelPumpReinstall1.jpg)
Until I get that fuel pic up, here's my latest update pic
Here is the BEFORE:
![](http://i19.photobucket.com/albums/b188/dejacky/EngineBayInstall.jpg)
#127
Former Sponsor
you dont have to cut a hole, route the vaccum line thru the fender hole by the canister, and then route the line inside to the cabin thru a rubber grommet near the area where the fender and firewall meet, you will have to remove the fender liner to see what i am talking about.
#128
when i bolt down that rubber piece, the vaccuum hose would be squished shut. Therefore, I have to cut a small hole in that rubber piece that covers the firewall hole correct?
#131
#133
yes you can. most gauges come with a gromit and line for you to drill through though. this is to redule how large the line is coming into the cabin and help with accuracy. i would make a hole for the boost gauge since it will be on the driver's side instead of the passenger side where the ecu is.
#134
MAP-ECU mounting idea: I like a similar layout like this because everything is at the same level and will not be a "bump" for a passenger's legs, thus decreasing the already little leg room available. It seems like I'll need to make 2 custom brackets to make this work, but I'm worried about anything shorting out. Can I just leave everything "as is" in the picture? It seems like three boxes will be plenty stable with the carpet over it. What do you all think?
![](http://i19.photobucket.com/albums/b188/dejacky/MAP-ECUMounting1.jpg)
I've decided to use 3M Exterior double side tape since it's easy to find, use, and seems like it will work great. Anyone agree/disagree?
