what is that turbo????
for turbo experts
I can buy turbo from my friend
it is from raylly cross
he is not sure about that turbo
no any specs
what I find:
on turbo is writen:
Type: T4 ROTARY
part no: FC3S/FD3s
serial no: MZ04050
compresion side:
intake hole: 76 mm (3")
comp air hole: 50 mm (2")
compressor wheel: inducer/exducer: 55 mm (2.16")/70 mm (2.75")
on comp side is writen A/R.60
turbine side:
exhaust gases hole: 70 mm (2.75)
Turbine wheel: not sure but smaller is about 66 mm (2.6")
that is all I know about that turbo
is that t3/t4 combo or t 62-1 or something else...?
thanks
for help
Jerry
no any specs
what I find:
on turbo is writen:
Type: T4 ROTARY
part no: FC3S/FD3s
serial no: MZ04050
compresion side:
turbine side:
thanks
for help
Jerry
Originally Posted by kaotiq
Straight from and made for the RX7, FD and FC generations.
The turbo can be used on any manifold that has a T4 flange however.. And its also equivilent to a T66 or a T61 based on the inlet.
thanks
I plan use it for my lexus sc 400 as single turbo
I want from 6 psi on first stage and next maybe 12 psi on second stage (that mean from 35 to 55 lbs/min ail is needed)
will be that turbo good for my 1uzfe and for my set up?
is that something as Master Power 62-1 in flow or higher or lower?
do you have any link for that turbo on rx7 community?
what hp they make using it?
thanks
that will help me much![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Jerry
thanks
Jerry
Ali2GS300
Performance
02-05-17 01:18 AM
