sc300/400 rear pumkins compatiable???
Anyone know 100% for sure
that the rear pumpkins from a SC400 and SC300 are interchangable???
if so can the same axles be used?
thanks
thanks
Originally Posted by PERRYinLA
Only in late October!
Originally Posted by Nomis
Is that a no?
As far as I know, the only time my car had pumpkins is when I took my girlfriend's kids trick-or-treating.
Yes, they are all compatible to my knowledge, all using the 7.7" ring gear setup and pumpkin. Obviously the gear ratios are going to be different. However on the Supra Auto will swap, not the 6spd which uses an 8.8" ring gear requiring a different length axle.
