car troubles
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
When I stop at any stop light, my car seems to be jilting and wanting to lurch forward. And sometimes past speeds of 70+ the car seems to be shaking a little. What is the problem and how much it would it be to fix? Thanx.
- Nizhu
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
- Nizhu
Everything is fine, it just jolts a little bit. LIke when I just start driving it. Hours later, everything is still going fine. I know that the timing belt can cost up to 800-1200. How much is it to balance out the tires.....?
- Nizhu
- Nizhu
Tire Balancing doesnt cost very much, maybe $10 per tire. Get it done, it makes a huge difference in terms of vibrations at higher speed. It's one of those cost effective things. Usually balancing is done with every tire rotation.
- Nizhu
- Nizhu
Normally timing belts don't need adjustment and if you're handy with a wrench you can DIY. I did mine on my SC300, its not hard, just tedious.
Quick VR-4
Performance & Maintenance
12-20-06 06:32 AM
