WARNING LIGHT on top of the temp gauge (by the H that looks like a gazzibo)
i started up my 94 SC400 this morning and the warning light on top of the temp gauge lit up. its the one on the upper left hand side of the gauge cluster. its a square with lines and point on top.....kinda look like a gazzibo.
what is that? and what should i check?
its a low coolant level warning light i beleive......mine always comes on in the morning when the car has been sitting for quite a while and it will go away after the car has been running for about 10 minutes......
Yup, low coolant, I think its suppose to resemble a radiator. Anyhow, check your coolant, it could also be the sensor, on my SC400 it was the sensor, coolant was never low, but if you were to push on the sensor the light would go away.
-Minh
-Minh
