New Dyno numbers for the SC300!
Hey congrates....very nice numbers. I'm wondering what turbine A/R your running? Just asking so I can put some idea of spool up with that turbo in regards to other turbine choices.
Thanks
Thanks
Well, it depends on what you are asking on the "a/r" or turbine side. My hotside/exhaust a/r is 1.02
As for the wheel, let's just say its larger than a 76mm
On the dyno we are dead on 11.2:1, which should translate into about 11.5-11.7:1 on the street. Leaner is meaner, but I don't I am pretty conservative.
These numbers were all done on 110 octane with 12 degrees of timing... VERY conservative!
Good info, thanks again. My assumption will be that your spools a tiny bit slower than a "standard" GT42R thenm if that sounds correct to you?
