How well do stock mufflers flow?
Old 08-24-05, 10:29 PM
Dramon
Dramon's Avatar
Default How well do stock mufflers flow?
I have an SC300 and was going turbo. I was planning on keeping the stock catback as I don't relaly like loud cars. For the most part on most older cars the most power gains come from removing the cats, which i'm doing but I was also wondering how well the stock mufflers flowed.
Becuase i'll probably end up keeping them. As long as theyre not a HUGE restriction.
Thanks.
Old 08-25-05, 06:34 PM
Dx3
Dx3's Avatar
Fellow Okie,
Are you still going to run larger piping?? From what I understand most people say to go to 3" piping for turbo. Stock is 2.25"
The resonators are the most restrictive part of our exhaust systems. The mufflers aren't too bad. However, if you go 3" and remove the resonators, then you are going to be loud anyway!!
Jonny
Old 08-25-05, 06:36 PM
got_trd
got_trd's Avatar
Take it to the dyno and compare it w/ the stock mufflers and w/ aftermarkets
Old 08-25-05, 06:40 PM
2JZSoarer
2JZSoarer's Avatar
NA cars are louder than turbo cars anyway, if your aftermarket muffler is big enough and is packed with enough sound cancelling material you shouldn't be too loud, and shape of muffler affects sound decibel too
Old 08-25-05, 08:01 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
Hrmmm.. interesting, as I would like an exhaust on my Soarer VVTi (shares the same pipework as an SC3) BUT I don't want it loud. I don't mind if there's a slight note to it but my exhaust on my old Soarer was hell drony, which is something I really want to avoid.
Interested in the GReddy MX... but I haven't seen anyone in Australia with this exhaust... I wonder how it sounds?
Old 08-25-05, 10:14 PM
dejacky
dejacky's Avatar
Thumbs up
I'm keeping the catback exhaust in my car and only having a 3in until the stock Dual Y connector. Stay tuned to hear and see the results .
Old 08-25-05, 11:50 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
dejacky that sounds interesting dude, keep us posted as this is what I was thinking about doing myself too (3" dump/2.5" mid pipe to OEM rear pipes... with all the OEM resonators and mufflers in place).
Jose
Old 08-29-05, 12:15 AM
Dramon
Dramon's Avatar
Hooray for dejacky!!
Old 08-29-05, 06:04 PM
Mikethe1st
Mikethe1st's Avatar
Go with an electric/boost dependent exhaust cut-out from wherever (www.atpturbo.com). I had two on my z. It kept it very stock looking/sounding (this is very important in California), until you opened it up and all hell broke loose.
Old 08-29-05, 11:53 PM
Dramon
Dramon's Avatar
see i was considering that but i've heard stories of them leaking, so i dunno
Old 08-30-05, 06:28 PM
Mikethe1st
Mikethe1st's Avatar
Some did. Some of the electrics have two small bolts holding the plate on. They tend to fall off so I had mine welded on. I could put my hand next to it and NO LEAKS. I saw at SEMA a newer style that had a much better sealing system which had a very nice machined seat for the plate to seal against much like a valve. You heard stories, did they actually have one???
Old 08-31-05, 11:06 AM
pilip99
pilip99's Avatar
i think loss of power comes from resonators..
Old 08-31-05, 07:13 PM
Lex Luthor
Lex Luthor's Avatar
IMO it's the perfect way to build a sleeper. 3" dp into 3" midpipe into stock rear section. Did mine this way and had no problem making power...and it sounded the way a Lexus should...quiet.
Old 09-01-05, 03:04 AM
BLK13X
Mortgage Slave
BLK13X's Avatar
Hey LL do you have any pics of the exhaust set up on the silver beast? I don't think I've come across it before. That's exactly the set up I was looking at for Soarer (except maybe 2.5" to OEM rear section as I'm not looking at big numbers).
Old 12-06-05, 03:39 PM
dejacky
dejacky's Avatar
Thumbs up
Jose
This is how it is now, but I decided to go with a custom dual 2.5in exhaust instead..I can still use that middle 3in piping though .
Quick Reply: How well do stock mufflers flow?
