help with cold start
Old 08-26-05, 02:46 PM
ChronoJ1
ChronoJ1's Avatar
Default help with cold start
Whenever in the morning or afternoon (not even cold, 80 degrees), when I crank a cold start, the engine sounds like its choking. I have to turn the key 2-3 times to get it started, and when it does start, the cylinders fires one bye one. So it start out at 100 rpm then takes a second to go up to 1100 rpm. What could this mean?
Old 08-26-05, 07:19 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
Sounds like a dead...
* Starter motor
* Alternator
* Battery
to me... I remember my old Soarer TT would have a hard time trying to start (it was in spring weather) and the revs would slowly rise from 400RPM to 700RPM on idle because of a deep fried battery.
Old 08-26-05, 10:44 PM
ChronoJ1
ChronoJ1's Avatar
* Starter motor
* Alternator
* Battery
Battery! Very probable. (alternator repalced 5k ago) I noticed my clock was reset as well. That means the battery was completely dead at one time. I wonder how the engine fired up though.
Thanks.
Old 08-28-05, 06:19 AM
BLK13X
Mortgage Slave
BLK13X's Avatar
No probs, hopefully it is the battery, as then it's not too expensive to fix/replace.
When my battery was on it's last legs, every time I'd go to start the car, instead of getting a healthy sounding starter motor (ie. the starter motor doesn't seem to be labouring to badly) it sounded like the starter motor was having a real hard time trying to start it (as in the starter motor sounded like it was going to give up).
I can't remember if my clock ever reset itself but the way you describe the car slowly rising the revs at idle is kinda similar.
Good luck!
Jose
Old 08-28-05, 10:29 AM
aswang
aswang's Avatar
how's the humidity like over in Michigan? When you check your battery, check to see if any corrosion has occured due to any acid. I just had to replace my terminals and when ahead and put a new battery on my ES300 not to long ago.
Old 08-28-05, 11:21 AM
ChronoJ1
ChronoJ1's Avatar
I just installed a optima red top.
What a difference.
1. When I start the car, the engine turns at least 20 times faster than it used to.
2. Idles and accelerates so much smoother.
3. I don't get the whole dash blinking when the turn signal is on.
4. Less noise from speakers at high volume.
Thanks everyone.
Old 08-29-05, 05:29 AM
BLK13X
Mortgage Slave
BLK13X's Avatar
Good stuff Where's my cookie
isthrizzy
05-01-13 05:43 PM
ChrisG1000
08-11-11 10:40 AM
Prost
01-25-05 09:56 PM
DroppedGS
01-21-05 03:53 PM
Handogen
RX - 1st Gen (1999-2003)
09-30-04 01:19 PM
Quick Reply: help with cold start
