One Messed Up Day (Plz Help)
One Messed Up Day
well guys today I took my baby for a alinment, then she was off to get detailed. when we went to pick up the car the guy goes: "ya its vibrating a little it should go away".
We also had an appointment to get Freon in tha A/C so not to miss that we didn’t pay to much attention to what the guy was saying.On the way there she shuts off, sum how we got it started and went back to the detail shop to find out that THE IDEOTS sum how got the spark plugs wet we took the plugs out at the detail shop, cleaned em. Unfortunately we couldn’t get to the one under the manifold so we got 4 cleaned got her started, but she is still shaking. At this point very little, but noticeable. she is still shaking espesialy under 1000RPM. what should i do?
And the A/C guys, they pressure test the system and said it was leaking around the A/C pump and they mentioned that the Lex uses R12 Freon (its a 93) and it hard to find and that it would be easier to convert it to use new Freon, is that true?
And I want to take the throttle body of to get to the two other plugs
Can sum one plz help
>>>EDETIDE<<<<
>>>EDETIDE<<<<
Originally Posted by $C300
well guys today I took my baby for an alignment, then she was off to get detailed. when we went to pick up the car, the guy goes, "ya its vibrating a little. it should go away." We also had an appointment to get Freon in the A/C, so not to miss that appointment, we didn’t pay too much attention to the vibrating. On the way there, she shuts off. We some how got it started, and back to the detail shop. There we found out that THE IDIOTS some how got the spark plugs wet. We took the plugs out at the detail shop and cleaned them. Unfortunately we couldn’t get to the ones under the manifold, so we only got 4 cleaned. We got her started now. She is still shaking at this point, very little but noticeable. We get it to the A/C guy next, and they pressure test the system. It doesn’t work because it is leaking around the A/C pump. They mentioned that the Lex uses R12 Freon (its a 93) and its hard to find. They told me that it would be easier to convert it to use new Freon.
And I want to take the throttle body off to get to the two other plugs.
^^^I edited the quote a little, to make it somewhat easier to read.
in in burbank, next to glendale
this is so agravatin i want to work on it myself i like workin on it it just that i have to get over the "i might screw sumthin up" feelin.
can sum one plz tell me what i need to remove to get to the 2 center sprak plugs.
To get to all the spark plugs, you need to remove your throttle body. This includes 2 electrical connections, 2 coolant connections, and 4 vacuum hoses. The only hard part is one of the coolant hoses that connect on the bottom of the throttle body... it's a biotch to get to.
as far as the AC goes, its better to go ahead and convert it to R134a. as far as the shaking... this once happened to me when i cleaned my engine bay. it ran like crap for a few days. on the 2nd or 3rd day, i thought it was about to die as i was pulling into my garage. the next day, it was fine. it wasnt long after that, that i changed my cap and rotor anyways. i would let it run for a while and see if some of it goes away. good luck.
to get the plugs out, you need to slide your trottle body over a bit. it does not need to come off. just take off the intake, remove the 4 nuts below the trottle body that hold on a bracket. then remove the nuts and bolts holding in the trotle body. slide the TB out of the way... not too much, as you do not want to pull off the coolant hose at the bottom of the TB. use a swivel on the socket for the plugs if you need to... they will come out. good luck.
in the future, please try a bit harder when typing... i was reluctant to reply simply because it was very difficult to read what you typed. thanks.
Tnx for the info I will keep all of it in mind but I still wont be able to rest until I resolve the problem.
I will be checking the sparkplugs tomorrow (hopefully).
And again I apologies for the typing I was very angry when I wrote it I have edited it hopefully it’s a bit easier to read.
shake
use an air compressor to blow off the air along the head/spark plugs..
check distributor. remove the cap and use compress air to dry it and the wires.
hopefully water did not get into your distributor.
good luck.
good luck.
Its easy as heck to take off the TB... You can bypass the coolent to your throttle body in the process also Its not hard, i can have the fuel injectors swapped from start to finish in less then 45mins, you can do it
