mohdparts egr removal kit.
Old 09-10-05, 10:21 PM
Inabj2
Inabj2's Avatar
Originally Posted by 96sc3
how many lines does the egr have?,.., which lines are runnign to eachother and which are capped?
Lines that stay 3.. Just do it man just do it I promise you its pretty straight forward once you remove the egr vacum and egr valve itself.
its the 3 lines which run directly into the EGR modulator and egr valve itself. Coming underneath from the y shaped intake piece.
heres what I did with them..
Old 09-10-05, 10:24 PM
Inabj2
Inabj2's Avatar
Capped this one...
Old 09-10-05, 10:27 PM
Inabj2
Inabj2's Avatar
EGR Bottom block off plate, made from a spare egr gasket I used as a template. Notice the use of washers to compensate for lack of width for the steel sheet. While its certainly more then thick enough to do the job. Its not thick enough to use the stock bolts. In this case 3 washers for each screw was necessary. I still left the stock egr gaskets underneath to make sure it gets a good seal. No type of sealant is necessary.
In top block plate only one washer for each screw is needed.
Old 02-16-08, 08:59 PM
1siksc
1siksc's Avatar
sorry for bringing this old thread back up but does any have anmore pictures of all of the vaccume lines in their engine bay? or could someone take some photos for me thanks - Chris
Old 02-18-08, 02:48 AM
Grimmig13
Grimmig13's Avatar
EGR valves are an emissions control device for idle and part throttle driving, most cars shut it off once the car has come up to temp. All removing it does is make it harder for you to pass emissions, and give the tuner community a bad name when people outside it hear about us disabling emissions control devices.
SCereal
SC- 1st Gen (1992-2000)
16
03-27-14 02:17 PM
sj408
03-18-10 09:02 PM
turbodremz
12
09-19-09 02:17 AM
jayesays
12
04-27-03 02:04 AM
Quick Reply: mohdparts egr removal kit.
