spacer for timing belt cover
Old 09-12-05, 03:12 PM
dean s
dean s's Avatar
Question spacer for timing belt cover
how impotant is the spacer for the belt cover and where does it go ?help left over parts!!!!!!!!!
Old 09-12-05, 03:46 PM
mikeloc24
mikeloc24's Avatar
Dean, I've seen SC's (mostly turbo's) without the timing belt cover on at all, so I don't believe it's all that important in terms of drivability. But leftover parts are normally a no-no in my book. Can you post a pic of what you're referring to? I'm drawing a blank on the TB spacer...
Old 09-12-05, 06:17 PM
dean s
dean s's Avatar
Default the spacer
mike its about an inch and a half square made of some kind of brown fiber 1/8 of an inch thick have know idea where it came from so I just said the hell with it after taking the fan hydro pump off for the forth bloody time! well I'll be able to do this in my sieep the next time!!!!!
thanx mike
Old 09-13-05, 03:42 PM
FloridaSC
FloridaSC's Avatar
thanx mike
Sounds like the cover gasket. Just keeps the water out if thats what it is.
Old 09-13-05, 08:09 PM
dean s
dean s's Avatar
Question
which cover floridasc ,left or right?bottom or top?
Old 09-14-05, 01:55 PM
mikeloc24
mikeloc24's Avatar
Fan hydro pump? Do you have a 400 Dean?
handoi9
04-18-14 04:20 PM
glbg
12
12-12-13 04:15 PM
Kauz
RX - 1st Gen (1999-2003)
01-06-13 09:05 AM
atropine
15
08-28-11 07:49 PM
Avery
07-07-10 05:28 PM
Quick Reply: spacer for timing belt cover
