Idle problem after flywheel install.
I expected high idle after installing lightweight flywheel, somewhere around 1100 or 1200 but my car is idling at 1800, have no idea whats going on. i am pretty good when it come to suspension and stuff but transmission and engine, i am retarded a little. Help me out guys.
Brandon.
Brandon.
Brandon.
Brandon.
I know that certain types of engines do not take well to lightweight flywheels, since it changes the severity of harmonic resonations (or the RPMs at which they occur) of the crank. Same goes for some engines and lightweight/underdrive crank pulleys... A lot of engines do not use counterbalance shafts, they just have harmonic balancers in the pulley.
Anyhow, first off we should be trying to help MongolKhan. Speaking of which, I don't think I have any advice to offer mate.
Secondly, we should probably discuss the effects of a lightweight flywheel on the 2JZ... Just my $0.02.
the flywheel should be neutrally balanced on these motors, right? i just had my stock one resurfaced when i did my 1jz swap and new clutch this month. isnt there a screw you can adjust by where the throttle linkage is on the throttle body? maybe you can move that some to lower the idle a bit. theres probably a proceedure to setting the idle speed that i dont know about, but maybe adjusting the screw will do the job. hopefully somebody knows more about this than i do.....
Ok, found out the problems, its a little silly too. I opened up my hood and looked over any loose hoses, screws then went under the car and couldnt find anything, so thought maybe throttle cable is too tight and when i checked it, cable was removed from its clipping place and pushed underneath some other clip, so i pulled it out of it and put it in the right clip where its suppose to be, start the car and it idles perfect. I was so relieved so i took it for a drive at 11pm. Car revs up so easily now. I put a ACT clutch and Clutchmaster flywheel and changed all the bearings and main seal of course. Thanks for your advise guys.
Brandon.
Brandon.
Brandon.
Brandon.
BTW - What was the weight difference between the stock flywheel and Clutchmaster?
Brandon.
Brandon.
You muttafocker - I just saw this post.
"You" though the throttle cable was too tight?
Please biatch! Who was the litte sloot that called me and said, "hey, blah blah blah... blah blah blah. what can be wrong?"
I told you to ck the throttle cable. Damn, at least give me some credit.. don't come up here acting like you figured it out all by yourself!
You're story should have read like this:
Ok, found out the problems, its a little silly too. I opened up my hood and looked over any loose hoses, screws then went under the car and couldnt find anything. So, like the little helpless poosay I am, I called my buddy runyun. He asked what the problem was, what the symptoms were, and gave it a second to think over. He wisely advised to check my throttle cable. I checked it, and realized the cable was removed from its clipping place and pushed underneath some other clip, so i pulled it out of it and put it in the right clip where its suppose to be, start the car and it idles perfect. I was so relieved so i took it for a drive at 11pm. Car revs up so easily now. I put a ACT clutch and Clutchmaster flywheel and changed all the bearings and main seal of course. Thanks for so much for being so wise runyun. I will definately give you credit for this one.
Who's your uncle biatch!
obviously, you don't know sarcasm when you read it.
me and brandon go back from when he used to live in texas. we email each other 50+ times a day to kill time during work until recently 2 wks ago today when he quit his job.
so, instead of trying to come across as a smart *** - just let me and brandon have our fun
deruvian
Performance & Maintenance
07-07-07 02:14 PM
