Sc300 5-speed Vs. Is300 5-speed
Originally Posted by Bean
Never meant to insult your intelligence, I know you're a bright guy
And yeah I never argued the point that IS3 guys used the W58, because I know thats true, I've seen it done a few times, quite an easy swap IIRC. Uses just a different tranny,but the same bellhousing, tailshft, etc
I know who it is that ran that much power through his W58, and it does hold it; but he doesnt drive it hard either... from what I gathered.
Again, never meant to insult you, I know you're not stupid.
its all good brother. if we are thinking of the same member..... then i feel that 12 sec. passes are considered hard driving. i dont know... im sure he will jump on this thread sooner or later.... he loved that W58 of his.
help me guys i have a 2002 is 300 auto and would like to do a 5 speed swap can i used the driveshaft,cluth pedal,clutch slave,cluth master,5 speed emu and diff from a sc300 5 speed manual car--------what can i used from a sc300 5 speed donor car
here is my .02
w58's are plentiful.Heck my stock sc had one. when my 1j decides to toss one, i go to the junk yard and for 80 bucks i get one. Then i pull my trans in an hour, spend 2 hours cleaning the new trans/ swapping the bell housing/ tail shaft/ speedo gear over.
The only bad side is that sometimes the tailshaft doesnt fit. there fore you only have the back 2 bolts holding your trans in. But thats ok for me.
TL: DR
W58'S are cheap and came in every non turbo supra and some celicas (might have been w56)
TL: DR
RougeSC300
Performance & Maintenance
10-29-17 07:16 PM
ronricorum
SC- 1st Gen (1992-2000)
12
12-16-09 11:28 AM
