Sc300 5-speed Vs. Is300 5-speed
do these cars have the same transmission? or are they diffirent? which one has a stronger transmission?
CEO
NO! the SC300 uses the W58 tranny in the 5speed, whereas the IS300 uses the W55, which is not as strong from what i hear. a common swap for the turbo IS guys is the W58 out of the SC. it has been proven to hold over 500WHP. hope this helps.
Originally Posted by ummagawd
actually... the SC's stock W58 has been known to blow out at as little as 300ish RWHP and hold up as high as 500RWHP
I've seen quite a few W58s go from as little as 350ft-lbs of torque. The IS300 W55 is even weaker than that. Though the W55 from the 22R-based toyota trucks is supposedly a lot stronger internally (and can be had for dirt cheap)
actually, i have seen an SC running the W58 with over 500HP at the wheels. if you dont slam the gears, it will last. numerous 12 second passes and countless dyno runs and it worked fine. now no more back talk out of you
what?
the IS guyes don't swap the W58 in sorry
if anything they do a R154 or the GETRAG
but they don't do the W58 swap...
The IS300 5 speed has a weak 3rd gear that likes to shatter.
haha, actually, a friend here in town swapped in a W58 in favor of his W55 due to the fact that it is stronger, and more cost effective than the 6speed. his turbo IS dynoed at over 500HP.
EDIT:
this was copied directly from his web page...
Engine:
Garret GT35R .68 A/R
Toyomoto Tubular Manifold
80mm Throttle Body (LS400) thanks DAS
Shaved Intake manifold
20x10x3 Front mount intercooler
3 inch Intercooler piping from the intercooler to the TB
3 inch inlets on the FMIC
2.5 inch piping from turbo to intercooler
Vortech blow off valve
Supra TT Internals (pistons, rods, rings, bearings)
Boost Logic Turbo Blanket
Haltech E8
Toyomoto return/fuel system
Walboro pump
720cc injectors
Tial 40mm Waste gate (open dump)
HKS Hi Power 3inch muffler (angled up and out)
3 inch exhaust
3 Inch down pipe
No governor
1mm head gasket (TT internals)
PLP non vented radiator panel
Transmission:
W58 (SC300)
-Clutch masters double diaphragm Kevlar disc
EDIT:
Engine:
Haltech E8
Walboro pump
720cc injectors
3 inch exhaust
3 Inch down pipe
No governor
Transmission:
W58 (SC300)
it might have held 500whp fine on 1 car by barely driving it, shifting slowly, etc... but 'proven to hold 500whp' means you can drive it like a normal car and push it without it exploding... the W58 won't do that. period.
And I know you didnt mean to say that the W58 is stronger than the V160 right?
first off, i was arround for the whole f-max vs. toyomoto crap. i remember posts my computerwiz, and i remember when he passed. i have been posting since 03, but i was browsing the forums long before.
the SC that im talking about that ran the W58 is another member on the forum. everyone that has been here for a while has seen dyno sheets and timeslips of his car using the W58. he drives the car daily, and when i say drives... he really drives it. eventually it did break. im not saying its better than the V160... that is what he is running now. im not stupid, im just saying its not a horrible tranny. believe me, i would much rather have either the R154, or the V160 over the W58, but that does not mean its crap.
as for the IS... i was just proving that there are guys that use the W58 in them. i could probably get a dyno sheet from him. he has not taken it to the track, and i dont know if he plans to.
Is the R154 tranny really worth swapping in, I mean how much abuse and power can they take compared to the V160? I am in the proccess of building my NA-T w/ goals upward of 600WHP and for me money does not grow on trees, so would the R154 be up to the task?
And yeah I never argued the point that IS3 guys used the W58, because I know thats true, I've seen it done a few times, quite an easy swap IIRC. Uses just a different tranny,but the same bellhousing, tailshft, etc
I know who it is that ran that much power through his W58, and it does hold it; but he doesnt drive it hard either... from what I gathered.
Again, never meant to insult you, I know you're not stupid.
