2JZGTE JDM Wiring help for SC300
Originally Posted by SC300_TT
so is this book realy worth $195. i thought about purchasing it but i didnt want to buy it just to find out that its not that good.
If you do a little research, you will see that it is regarded pretty highly. He spent alot of time getting it all together. A good investment that you can resell later if you need to
It's no longer $195 either. It's $95
John
I am bringning it back from the dead.. but i have a question.. i want to swap the 2jzgte in my 5speed sc300, if i buy everything usdm (engine, harness and 6speed ecu), do i still have to rewire the harness or it is all good? and if i do have to do something is it something big or not? like couple wires to swap...
i know that if you go with the jdm engine and harness, there is a lot of harness modification from what people says... i was interrested by the jdm but all the usdm spect seems to be better (everything is bigger already injectors and turbos) the probleme is that it seems to be harder to find a usdm.
can i run the 6speed ecu with the 2jzgte but with my 5 speed tranny. Somebody once told me no but i believe read yes on the forum. just need a confirmation
thanks
thanks
There is modification needed for the us harness and the jdm harness. The aristo harness needs extensive modification. I am currently working on figuring out the wiring on the aristo harness so it will work in the sc300. You can use the us and jdm harness and auto or 6spd ecu with your 5spd.
So.... logically speaking, if i were to get my hands on a usdm 2zjgtte motor from a supra, i would basically be able to drop it in directly to the sc300 with no issues at all??? my hope would be to do something similar to this, and just go aftermarket standalong engine management and go from there... am i on the right track?
