View Poll Results: How do you tune your car? Vote now.
Stock
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
34
27.42%
Mechnical adjustment (ie. rising rate fuel pressure regulator)
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
7.26%
Piggy Back Computer (eManage, S-AFC, etc)
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
46
37.10%
Full stand-alone fuel and timing computer (AEM)
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
35
28.23%
Voters: 124. You may not vote on this poll
SC Model: SC300
Induction: Turbo
Fuel: 550cc Denso Injectors / Walbro
Other misc upgrades: (ie. cams, crank, etc): Too many mods
Tuning components (fuel management, timing, etc.): PHR MAP-ECU / Apexi AVC-R
Issues: Rough Cold start (Later fixed due to wiring issue)
Fixes: Wiring of the MAP-ECU is a bit complicating.
Recommendations: Get a professional installer who has delt with the MAP-ECU before hand.
Induction: Turbo
Banned - could not follow forum rules
A good Piggy-back ECU, and a good tuner mechanic and your set.....Better yet a Good Stand Alone ECU and good tuner mechanic...Although some say even a tuned piggyback will not stay in tune for long, as the stock ECU learns and changes over time...So for tuning perfection it may be an ongoing process for some....
SC Model: SC300
Induction: Turbo
Fuel: Stock injectors, Walbro 255
Tuning components (fuel management, timing, etc.): SADC2
Issues: Need recirculation kit
Recommendations: If you don't want to go broke, don't get into modding!
Induction: Turbo
not a SC but still....
my sc will be boosted soon so i can add on later
Model: sr20 w/ ITB's dry sump, and TEC2
Induction: Turbo
Fuel: 750cc injectors
Other misc upgrades: FPR and Bosch fuel pump
Tuning componets: Electromotive TEC2 standalone
Issues: no base maps, custom crank trigger bracket
Fixes: get a MAT and MAP sensors, patience![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Recommendations: dont get it unless you have time, and money to have it installed. once installed its nice to work with.
Induction: Turbo
SC Model: SC300
Induction: Turbo
Fuel: Walboro
Other misc upgrades: single ct26 57trim
Tuning components (fuel management, timing, etc.): Apexi SAFC 2
Issues:stock o2 with ecu relearns everything from idle to partial throttle (closed loop) soooo annoying so i cant tune anything that isnt WOT.
Fixes: get a standalone or play with the afc all day while youre driving
Recommendations: safc is ok with a wideband but go with a power FC FTW!
if anyone has had better luck with safc during closed loop please chime in!
Induction: Turbo
Fuel: Walboro
SC Model: SC300
Induction: NA-T (T67 turbo, 2.5mm head gasket)
Fuel: Walbro pump, 650cc injectors, stock lines and fuel rail
Other misc upgrades:![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Tuning components (fuel management, timing, etc.): MAP ECU
Issues: None
Fixes: Be patient
Recommendations: MAP ECU
Issues: None
Fixes: Be patient
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
1992 SC300
2JZ-GTE
Walbro, stock fuel system (USDM 550's and resistor box)
AEM EMS
540whp/500wtq 19psi, pump gas.
No issues whatsoever. If it's tuned correctly, AEM is the way to go.
2JZ-GTE
AEM EMS
Jon
