Help! 1JZ Wiring ECU
the square grey one looks like one of the ecu plugs for sure, and that rectangular white one plugs into the side, where the kick panel is....right next to the orange plug. seems like youre missing one?....thats wierd. btw what did you do about the knock sensor wires when you extended the ecu harness?
wierddddd......my computer looks different...you probably have a clip out of a chaser or something...in which case you probably need to splice one of the plugs from your 1jz harness into a plug from your ge motor. going into the kick panel area there should be two grey, two white, and an orange plug...but that still dosent explain why your plug dosent fit into the ecu. here's a picture of my ecu before it went in the car.
wow thats a wiring nightmare, my harness didnt look liek that lol, it was complete and ready to go.... when i get my harness back this weekend i can tell u what color wire goes where.
i have no idea what kinda hacked harness that is.... maybe to swap the 1JZ into another shell??? Start callin around for another harness, that one looks pooched
