SC300 / 1JZ 5 Speed not running
09-29-05, 09:01 AM
If anyone has had this problem or heard of it please help. When the car is cold it starts up fine and I'm able to drive it around the block once, all of a sudden it starts to hesitae and misfire then shuts off. sometimes I could start it right back and sometime it sounds like its flooded. When it does start back as I take my foot offf the clutch the car shuts off. I've changed the coil packs the fuel pump the map sensor the ECU and also the temperature switch.
If you can help please do.
09-29-05, 12:31 PM
any black smoke or anything unusual?
09-29-05, 12:33 PM
no black smoke. like I said when it starts bak it idles fine but as soon as I rev the car or try to move it shuts off.
09-29-05, 01:35 PM
Check the obivious spots? Plugs? Fuel Filter? Faulty Fuel Pump? There are plenty of other little things, but start there.
09-29-05, 02:08 PM
Same thing with my rents beater accord, fuel problem eh.
09-29-05, 02:16 PM
If it's a fuel problem, take it for a spin, wait for it to stall and get the rail pressure. Could be the pump is giving up once it gets hot.
09-30-05, 09:33 AM
It's definitly not the fuel pump and filter I replaced them with a new ones.
09-30-05, 03:42 PM
Knock sensor perhaps? does the car shut off when it gets warm / closed loop?
10-03-05, 08:54 AM
Hey guy's thanks I fixed the problem. I took the wire harness back out of the car and checked it for cracks and sure enough I found one.
INCLINEDI
Performance & Maintenance
09-28-12 03:22 PM
redman1
01-15-12 10:03 PM
tomtheslac
09-13-10 10:14 AM
na4now
10-04-07 11:42 PM
kathleenkmh
05-23-02 05:31 AM
