AEM standalone on 1UZ?
is this posible make AEM standalone works on 1uz?
that will be great if it can work.
I know that AEM make ecu for sc300 NA.
sc400 is all different or cane be modify to fit sc400 loom/configuration?
regards
Jerry
regards
Jerry
ok maybe that:
are sc300 ecu plugs identical phisically as sc400 (I understand that some wires cane be in plugs in different positions but question is about plugs)
another word: can I (phisically) plug in sc300 ecu to sc400 harness (I know it will not work elecrically).
Jerry
Jerry
no they arent identical at all
at autosportwiring they make wiring extensions so that people can use piggybacks without splicing into the factory ECU harness...
well they have in the past, made a 2jz-gte harness with open wires on one side... so AEM users that are adapting to the 1jz can use it.
They use the 2jz-gte AEM and settings, and splice the autosport harness into their factory 1jz harness... the AEM is programmable, so with a little meddling, you can make it work... and quite a few people have done this
i see no reason why you cant take the same harness and program the 2jz ecu to work for you too... tho you'd need to switch the settings to a distributor and a few other changes... but its possible most definitely
most worry is that JZ and UZ have different ignition systems. but perhaps AEM is so flexible and adjustible that can be programmed for controlling 1UZ engine ignition system. Any info about that?
I know AEM can controll tranny too, so it should not only help maximize engine controll but help eliminate that long gear changes at WOT too.
Originally Posted by JTJerryls400
thanks Bean
It doesnt matter. Once you have the right wires in the correct terminals, you can change ANYTHING. Before there was a 2jz-ge variant, people used the 2jz-gte and just converted the AEM over to distributor-based ignition and it worked fine.
You need to check out the AEM forum out there... there's TONS of info and they have adapted it to MANY MANY vehicles... from Ford F150s to Dodge Vipers.
thanks Bean
Originally Posted by jgscott
I wondered about the Retared timming gears changes too. I did some research and was told it may be hard as hell to find what controlls and where the shift retards.
Im not sure how the aem will work with autos. You might end up having to manual shift it. I know that it doesn't work with supra tt autos. AEM also makes a race ecu which is pretty much the same as the vehical specific ones that you can wire up to pretty much anything. I don't know if you have to buy the harness or it comes with it but its just a harness that plugs into the ecu with pig tails that you can wire up to your stock or aftermarket sensors. Since its not the pnp version, you have to setup the sensors for the aem to read it properly.
~Kevin
~Kevin
xspsi6
SC400 / 300 Classifieds
07-28-13 03:41 PM
JamesN
02-25-11 12:07 PM
