Headgasket for cheap SOB's like me
I decided to go with a TT HG to lower the compresion on my NA-T sc300 project.
The goal is 400whp as cheap as possible. The best price on a TT gasket was from carjunky.com.
$92.61 shipped
http://replacement.carjunky.com/part...asket&dp=false
Made by these guys in Japan,Taiho Kogyo Co., Ltd.
http://www.taihonet.co.jp/e/gasket.html
The quality is first class
$92.61 shipped
Originally Posted by kietlander
OEM TT HG will cost about the same check out rockauto.com i would rather get OEm
But then again most people on SF said the same thing when I used a cometic gasket on a friends NA-t and suggested they try it as well. They basically called the cometic gasket cheap crap and sugested among others a "high quality" 2.5mm BL headgasket. Guess what BL sells you the same cometic gasket for $100 more. Yes a BL gasket is a Cometic gasket.
But anyway,what makes you think rockauto sells OEM gaskets. They sell OEM replacemet gasket just like the one from carjunky does, but it cost more. (just a little) The rockauto gasket is made by CORTECO
http://www.corteco-usa.com/
You will not get a TT HG from Toyota for less as far as I know
SC300_704
Performance & Maintenance
11-08-07 04:21 PM
