Heat with air off
Heat with air off
It's finally under 100 degrees so I'm driving with my A/C off. The heat coming through the vents is getting annoying. Does anyone know if there is a common problem with a blend door not closing or something like that?
same thing happens in my car. I think it's a design flaw..there is a remedy, but I believe it requires some modification. I read about this a long time ago and can't remember where .
you will find that the heat you are expieriencing from the centre consul is probably due to the exhaust system running directly underneath it , this is certainly true on the V8 soarer
bean is right check that you have the option of pulling air from oustide w/ ac or heat . but our cars do have have alot of heat around the center console my supra is the same way but check thsoe options out
kaiser if you checked that out and its not that i agree with got_trd the heat comes from the tranny casue my supra also does that and keeps me nice and warm in the winter without the heater on i think it does that casue the tranny is right under you
