Heater not blowing HOT!???
Old 10-19-05 | 07:38 AM
Grier's Avatar
Grier
Default Heater not blowing HOT!???
I have a 93 sc4 and just had the thermostat replaced yesterday. Now I have no heat coming thru my vents, even with the temp on MAX HOT after driving for 30 min, still no heat. I feel like I can smell the heat but the temperatuire is not there. Anyone know what may be causing this problem?
Old 10-19-05 | 07:42 AM
ChronoJ1's Avatar
ChronoJ1
Try doing WOT.
If you get heating then, it's probably your water pump.
If not, could be your heater core.
Old 10-19-05 | 07:44 AM
Grier's Avatar
Grier
Talking
What is "WOT"??
Old 10-19-05 | 08:07 AM
King7Two's Avatar
King7Two
CL Folding 200000
Make sure you have coolant in the radiator, If you just replaced the thermostat...this could be the problem.
If there is no water going past the coils, then the hearter wont work correctly.
Old 10-19-05 | 08:09 AM
setwire's Avatar
setwire
Default No Heat
Sounds to me like you have an air lock in your cooling system
Make sure heater is on, engine is running radiator cap off.
Remove filler cap above themostat housing and add coolant untill it overflows.
Hope this helps.
Rob
Old 10-19-05 | 12:36 PM
ev0ti0n's Avatar
ev0ti0n
Originally Posted by Grier
What is "WOT"??
Wide open throttle. Pedal to the metal. Mashing it. Vroom. Wee. Yay. Crash.
gmoney94
02-02-18 09:31 AM
msc300
01-26-12 06:38 AM
Och
73
11-03-09 07:58 PM
Don Fila
11-14-05 01:05 PM
ACleanSC4
SC- 1st Gen (1992-2000)
01-05-02 11:23 AM
