Spark plug wires
Spark plug wires
My plug wires haven't been changed since 1994. Time for something new. So.. what does everyone recommend? Stock wires? MSD? Nology? Crane cams? Others?
Do wires from a MKIV n/a supra fit?
I'm planning to use some e3 spark plugs. Anyone ever use them?
Thanks
Thanks
I have the nology wires with the Beru plugs (non-resistor type) The wires fit a bit tight but not bad. Ihave had them for a while and no problems, or noise from the non-resistor plugs.
Originally Posted by RjRacing
They are the same
So, is it worth spending more on the nology wires?
So... anyone tried the e3 spark plugs?
i got supra n/a wires from the toyota dealership to put on my sc3. dont have experience with aftermarket wires though. i believe general consensus here and on supraforums is that factory wires is the best way to go
I find the Nology + Beru plugs are a bit better than just stock, pricey, but better. Gives my 92 SC300 bit more zip, but that is IMO. Depends on what you want , I just thought it would be easier than going the MSD route, and that is one of the reasons why I chose the nology setup.
wires
I'm new at the forum, but I'll tell you this, the stock wires for the sc400 are YAZAKI, and without a doubt they are the best. They actually guarantee those wires as lifetime wire.
92' sc400
-yazaki wires
-ngk iridium plugs
92' sc400
-yazaki wires
-ngk iridium plugs
92' sc400
-yazaki wires
-ngk iridium plugs
92' sc400
-yazaki wires
-ngk iridium plugs
http://www.magnecor.com/magnecor1/truth.htm
Interesting read I guess. I found those wires on ebay for like $130. Anyone recommend them?
llllllllll
IS - 1st Gen (2001-2005)
18
07-10-10 10:03 PM
