MKIV Supra auto shifter in SC300
Has anyone done this. I am trying to make it work,but it is going to be a PITA.
I hate the dildomatico So I got the idea to try a Supra Shifter. It bolts right in and the needed wirering is easy enough. Making it work in the SC's center console and not look ghetto is the problem. I will post pics of the shifter as it sits now.
how is it looking ghetto? i mean, does it look all hacked up when you put the plastic covers back on? but anyways its lookin good here. it's also something i would like to do with that damn sc shifter of ours
Zombie Slayer
Some nice work you're doing there nasc!!! Keep us all in the loop. Maybe a write up when you're all done on how you did the whole job to help us schmoe's out??
I got the complete shifter assembly from a TT for $50 shipped from a SF member. The shifter assemble bolts in but the lever is a bit short and located a bit further to the left (driver's side) than the stock shifter. As is the car can be driven and shifted into all gears,but the position of the shifter does not line up to it's respective mark on the console panel.
I am going to need to use some of the center console mounting brackets of the old shifter to get the center console bolted in and may have to shave the gate a bit on the left side. I may also have to extend the lever length just a bit.
I won't get anymore work done this week but will update as soon as I do.
