What to do 1jz swap for 99 sc 300
Old 10-28-05, 11:36 AM
96sc
96sc's Avatar
Default What to do 1jz swap for 99 sc 300
Thinking of doing the 1jz swap on my 99 sc, read some things online, what year will work with the least amount of hassle? Do in need the vvti motor from japan, ie single turbo model? Or Can i use the older less expensive model? Will the wiring be any more diffucult using the older model?
My goals are modest performance, probably would leavee it stock for a while, then slightly mod it to go into the 12s. Would like a daily driver, good gas mileage, i have heard people getting 25mpg with this setup? Not sure if you could get that good of gas mileage with an auto setup or would you need the manual? Any input would help from anyone who has done a similiar swap.
Thanks
Old 10-28-05, 11:43 AM
SoarerJzz3
SoarerJzz3's Avatar
I say go for the 1jz vvti model engine. Newer car newer motor. A member on here, vududoc has done a 1jz vvti manual in his 92 sc. Do a little search and you should find it.
Old 10-28-05, 11:57 AM
VJ RC51
VJ RC51's Avatar
OBD1-2 has to do just with the ECU i think?? The body plugs should be the same, or not much harder to make work with a bit of diagram reading and wire switching.
Id say go with the VVTi single turbo, new car + new motor = FTW
Old 10-28-05, 12:29 PM
96sc
96sc's Avatar
Default swap
my car is an auto, the vvti motors i have found are also autos, was thinking of doing a 5speed to get better mpg etc. I know it sounds funny, but if you can have the best of both worlds when not into the throttle? What kind of mpg do you get on your 1 jz swaps?
Old 10-28-05, 12:41 PM
96sc
96sc's Avatar
Default swap
Also what is a fair price for this setup? I found one in canada for 1000 for engine trans, ecu etc, same setup in the us for $1900 shipped. The canada one best i have found so far has been $500 to ship. These are both auto setups,vvti motors. There aren't many of the vvti motors around, plenty of older models. What are the advantages of the vvti?
Thanks in advance.
Old 10-28-05, 12:46 PM
VJ RC51
VJ RC51's Avatar
Unsure of vvti advantages, but my typical MPG when i dont drive like a madman spooling on every stoplight, is almost 25mpg.
Auto if im not mistaken auto gets better MPG, the cruising rpm on the highway is lower. Plus auto is really fun with turbo, no lag
Old 10-28-05, 04:31 PM
blksc300mt
blksc300mt's Avatar
25 mpg sounds like a lot...do you have an afc on your car?....around town with my 1jz driving it easy i get like 14-15mpg...maybe 16, and i just drove to orlando and back (from miami) and i got like 19-20mpg averaging 80-90
Old 10-28-05, 06:40 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
IMO the 1JZ VVTi is the go, any SC3 from 96 onwards should get that motor as that's how Toyota released them in Japan (personal opinion but anyway...). The VVTi motor also has a different torque curve compared to the older 1JZ and feels more linear than the older spec (which I used to have as well) giving it a more lively low-mid end drive too. Fuel economy between the two isn't too much of a comparison, for some reason I kept getting horrible consumption from my old motor compared to this one (my new 1JZ does about 9km/L in city driving, whatever that equals in MPG).
Excuse the dirty engine bay
Old 10-28-05, 06:42 PM
Mr. SC300
Mr. SC300's Avatar
Looks clean to me.
-romeo
Old 10-28-05, 07:38 PM
Aristo300
Aristo300's Avatar
Wow can the VVT-i valve cover be used on the old motors?
Old 10-28-05, 07:57 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
Not sure if that plug cover will fit. Hell just source a 1JZ VVTi
Old 11-02-05, 08:51 PM
96sc
96sc's Avatar
Default 1jz
Anyone else with any info? Thanks
Old 11-02-05, 08:59 PM
kietlander
kietlander's Avatar
21 mpg...not bad for a turbo car. i guess when im want turbo ill swap.
Old 11-03-05, 07:34 AM
VJ RC51
VJ RC51's Avatar
Around town i get 18ish mpg, highway going 80 (anything over 85 builds boost and kills mpg), i can get well over 23mpg. Bone stock 1JZ, no electronics.
Gotta love a proper and ohm tested wire extension
Old 11-03-05, 08:44 AM
Goldark
Goldark's Avatar
do you need anything else?
who can get the wire extended?
how long does a swap usually take? two - three days?
Quick Reply: What to do 1jz swap for 99 sc 300
