new radiator? Temp. Sensor?
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
I have a 1992 SC300 with a crack near the top of radiator (by the cap). Any one know of a good used radiator?
For now ,
I have patched it with fiberglass, but I don't think it will last.
In additon, in the winter time the heat fails about 1 day out of 10. I keep playing with the temp. control **** and eventially it goes on. I have changed the themostat 2X, but that hasn't solved the problem. Could it be the Water Temp Sensor? The OAT (what is this), the servo motor that
drives some mixing valve ( how do I check for this)?, Is the Water Pump going?, Is it the HOT
water metering valve ( where is this and how can I get to it) ?,
Help! It's starting to get cold, and I'm getting cold just thinking about it!
Don
For now ,
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
Don
The thermostat and water pump are not the problem, since presumably the engine gets hot and works fine. If you have a crack, then you're losing coolant. Once coolant level drops below full, one of the first things that happens is the heater stops working.
If it's not a coolant level issue, it may be those other factors you cite. Be sure to search previous threads to see how others dealt with it.
Thanks for your quick reply. i'm sure it's not a low coolant issue. Ii was happening last year.
since I'm new at this, any tips on how to search? Have you had tis problem?
Thanks Again,
Don
Thanks Again,
Don
For starters, I put "heater valve" in the search box and came up with these 68 threads:
https://www.clublexus.com/forums/sea...earchid=329613
You can narrow it down more, if you wish, by adding other words. If it was my car and my problem, I'd want to read up as much as possible.
Thanks for leading me to the radiator barn. I saved over 50% off the best price and of course
Lexus was asking $600 for it. Are you kidding me!! No I'm not!
Och
73
11-03-09 06:58 PM
