1JZ turbo coolant line????
the pic is dark so i cant see really... but theres a big metal gooseneck that connects to the heater above the rear turbo, and then u got the other port on the wrong side of the block that also does..
thats the 2nd heater core line... theres 2 of em. One goes on the firewall connection, the other goes on the valve. Its on the wrong site of the motor cause its for a rhd car
i'm in the process of this swap right now, and i was going to hook up the gooseneck hard line above the turbo to the short heater line out of the firewall. and then the longer rubber hose on the left side of the motor, i was going to buy a U and run that line to the heater valve. is that correct? tia.
MrFairlady
SC- 1st Gen (1992-2000)
14
02-03-15 09:49 AM
soarer479
Performance & Maintenance
07-30-13 03:24 PM
