$1000 to spend... on what?
#31
Originally Posted by iasc300
i want more Performance? (Primarily Engine Mods)
what would you recommend?
I would get your exhaust done. You can easily get some nice Magnaflow mufflers and custom piping for around $500.00 including labor.
You can pick up a set of shocks/struts and springs for about $500 also.
These will help the handling side of things.
Next, save up for rims/tires that can put the power to the road.
Turboing you current engine will cost about $5500 installed. $4500 for a Boostlogic.com turbo kit and about $1000 for labor.
This will get you about 320hp to the wheels (about 410hp at the crank) at about 7-8pounds of boost (according to them).
#32
Zombie Slayer
Originally Posted by $C300
There is a 1JZ on EBAY now for $999+ shiping with AT tranny, uncut harness, turbo ect...
http://cgi.ebay.com/ebaymotors/JDM-1...spagenameZWDVW
That's the GT motor. 2.5L Twin Turbo.
#35
Originally Posted by IronCobra
If you plan on turboing the car and using your current engine, time to buy prep parts.
as for suspension, you can get an inexpensive set up if you look long enough...(i think i still hold the record for cheapest set up at $75 for 2 week old eibachs and KYBs )
as for the turbo comment, i would have to disagree. you can turbo an SC for far less than $5500. one, you dont need the boost logic kit.... dave H has been proven to make just as much power for less than $2k. two, to pay someone $1000 for basically a "bolt on" is absurd. unless you have no idea what your doing with a wrench in your hand. the hardest part is drilling for the oil return.
i still agree though... exhaust, suspension and wheels (brakes too), and then go fast.
cobra, im not bashing, its just what i have learned over time.
Adam2562
07-01-09 05:05 PM
