important 1JZ swap info learned
You CAN NOT use the stock n/a radiator. I always ran my 1JZ with no thermostat, so it typically ran kinda cool, especially on the highway causing me to get bad fuel miledge. Well i put one in finally yesterday, runs fine, off boost. If you run on alot of boost it will overheat (not boil over, but boil into the tank). I had to pull the thermostat out this morning so i could drive it. Lesson learned: you can not use the stock n/a sc300 radiator, just doesn't cool enough when you get on boost and heat up the turbos (hot turbos = hotter water since they are water cooled). Koyo or aftermarket "stock" all metal supra TT rad is in the near future!
Originally Posted by soardrft
wow are you running 11psi or higher. i had my stock radiator on my last sc and it was fine at 12psi. maybe motor problems? just something worth looking into.
Maybe i just have a blocked rad..
EDIT: i dunno tho, my other stock sc300 with no overdrive will do the same dam thing if you go on the highway over 80mph.. Makes it run just a tad too warm, not enough cooling power with these things.
no boost guage? hmmm do u have a turbo timer? if not look at buying the blitz that has the boost guage on it. also how are your hoses? do a radiator flush. simple things before you invest and find out your investment was not worth it. good luck
no boost gauge, no turbo timer. Its a bone stock swap, just looks pretty.
Originally Posted by Kaiser
MIne works just fine and I live in the desert. I haven't turned up the boost yet though.
Its weird cause it runs colddddddddd with no theromostat, so cold it goes into closed loop on the highway and it runs rich, but if i run it hard with a thermostat and idle it down, it will still boil into the overflow tank. If i drive it normally with the thermostat, its fine. Only when i get into alot of boost and shut the the engine down even if i idle it down, will it boil into the tank, with the thermostat in. Water is crystal clear, no oil or anything.. headgasket is fine. No water leaks anywhere except a drop or 2 around the neck sometimes
Originally Posted by TurboTeg
VJ good info there. But dude, get a boost gauge
LOL why? I don't have a boost controller. i can put that $60 towards better things I figure if i blow a wastegate line, ill hit fuet cut
This info might be not accurate for brand new n/a radiators, but if yours is original and high mile like mine, its probably not going to work. Well works with no thermostat, but then u gotta worry about cold weather and the engine running crappy at highway speeds.
id start looking else where for why its running odd. modern motors are meant to be run with a thermostat for a reason, or any one with one built into the block for that matter. it may be an old hot rodder trick (in actuality a myth). id diagnose whats wrong with it first before you start modifying how the system runs. my buddy doesnt run a t-stat but then again when you have a methanol burning catipillar turbo'd corvette that runs 6.5's id say you dont need one....
What problem? Problem is my 13yo 150kmi stock radiator isnt cooling my 1jzgte. Its an old hotrodder trick also to pull out thermostat if you cant get enough cooling. There is no problem with the motor.
Originally Posted by Gibenstein
Ok so your saying that off boost w/ thermostat you run fine but when you get into boost you start overheating ? But when you run w/o thermostat with boost you run fine ? How old is the thermostat ?
Yep. Thermostat was brand new stant from autozone. Did it with the OEM one too, i thought it was bad and took it out and had none for over a month now. Ran fine when it was hot out, but now since its in the 50s, is causing me to go closed loop on the highway and i need to put something in there ASAP.
