VPC resistor location for 93 2jzge
I am having trouble finding the correct location to insert the resistor pins into the afm plug. From dave h's diagram it says to find B65 and B45. My problem is that b65 is a brown wire, on the afm plug there are 2 brown wires. I've tried looking through supraforums but it seems that their wire colors are diff than ours. B45 is a yellow/black wire (pin 2 with the clip facing up). Anyone know which brown wire (pin) I should use? Thanks
dejacky, how do you have your dipswitch settings setup? Mine are All off on the top and off,on,off,on on the bottom. Everything seems to be working but I don't know if it's correct or wrong since on some other diagrams I see on,off,on,off.
When you open up the vpc there are some switches on the bottom right. Two rows of them. What settings do you have them on? ALso where did you plug in the resistor? Which pins
Peter_95
08-07-08 10:25 PM
