Auto>Manual conversion SC300 - What is needed?
Registered User
I already have this posted in the classified, I'm reposting it here in hopes that some one can point me in the right direction, Mods if you disapprove I'm sure you will delete, but please leave the thread in the classifieds.
I have a 92 sc300 auto, converting to manual for a six speed, need everything necessary mainly off of the firewall, including pedel assembly, master cylinder, hell even the line.
I have already tried the dealer; said they couldn't get half of the parts
But any parts new/used if they will help please help me. Or even a point in the right direction, maybe someone makes a kit (minus the transmission). Thankyou in advance for any help.
i'm in a good mood so here:
https://www.clublexus.com/forums/sho...ghlight=6speed
its 1 of 67 other threads under '6speed' when you use the search button.
may also want to try 'getrag' or 'gte'
Registered User
Thanks Supra dr, but I know what I need and am capable of doing the conversion(needless to say), but I was actually looking to buy the parts. Now I have found a place that has both a 95 & 96 5speed, and I am assuming the pedel/master cylinders are the same, if I am incorrect some one please correct me. I was almost told that the mkIV was a possible candidate.
Registered User
You should be able to find all the parts you will need to convert on supraforums.com, search for auto-6pd, will come under Curt, he has listed all the part number needed to do a swap, hopefully that works out, good luck!
You can always goto a junk yard and find mkiv or sc with 5spd and part it out or look for stuff you think you might need, another idea, John
