catalytic convert hollowing/removal
Old 12-07-05, 04:29 PM
duckworth
duckworth's Avatar
Originally Posted by jbrady
Some good info here Duck but I hope you mean the V8 on a SINGLE 2.5" as dual 2.5" pipes are TOO large. Since the 1UZFE uses twin cats or 3 in the case of California and Canada models... the bypass should be made from 2.25" pipe. I also agree that it is best to keep the cats. Actually headers with high flow cats (preferably metal substrate) followed by a copy of the stock system in 2.25" with a single 2.50" center pipe.
i don't have a lot of experience with these 1uzfe engines yet, but so far in life, the same things apply to nearly every engine.......i'm gonna do some dyno comparisons since emissions isn't an issue here, because within the month i'd like to put an exhaust on......
the first 4.6 ford mustang gt benefitted from dual 2.5" pipes and that design is a bit archaic when compared to the 1uzfe isn't it? like i said, i don't know for sure and may be completely wrong, but for an engine that makes 250/260 with only 10:1 compression and no other tricks, the flow of air through the head shouldn't be an issue, and with a good exhaust, you'd have better scavenging with a dual 2.5" setup and hi-flo cats (one per side) and a good muffler........the increased airflow OUT would mean increased airflow IN and a cleaner burn.......the ONLY reason 2.5" duals would be too much is if the head wasn't capable of pulling equal amount of air in......a 2 liter 4 cylinder shouldn't be able to move that much air except for in race form (they'd still not use duals) but a 4 liter, 4 cam v8 SHOULD be able to.....maybe i'm wrong, i'll learn a lot when i hit the dynos after xmas, but logic says that the higher rpm will benefit a LOT more than the low end would suffer........i want headers too
I think he means the typical raspy blatty ricer Hondas that are so common on the street creating what is best described as noise pollution. I will add that hollowed out cats on any car including the Lexus V8 qualify for both air and noise pollution.
Regarding the unparalleled sound of an open header Honda turning 8000rpm... I just HAVE to say there are MANY V8 engines that sound much better than the Honda. Not saying a high reving Honda is trash... however a high reving V8 or V12 is superior. NASCAR, Top Fuel, Ferrari F50 (one of may all time personal favorites) and honestly my LS400 with 4 of the 7 muffling devices removed is flat out LOUD. Sounds like a cammed Corvette at idle and intolerable to this old man at any driving throttle position (drove a few miles turned around and put it right back together).
they're raspy and obnoxiously loud due to them being 1.6-1.8 liters on average.....the higher the displacement, the deeper the natural tone.......a 4 or 5 liter v8 doesn't sound like a sub 2 liter engine no matter what you do............you get a bubbling sound with hollowed cats due to the turbulence and thinner cat walls..........i figured he meant that, but that bubble doesn't compare to the wide open weed eater sound a sub 2 liter engine makes with bad exhaust setup........
and i'm not saying i like an uncorked small displacement engine, i actually hate them.....i've been building 4 cylinders for 10 years, had some fast ones, but they sound awful when open......even boosted 2.3 liters just don't sound good without a good exhaust setup.....
i'd much rather hear a v8 anyday.........even my hondas with 12 second n/a setups had nice exhausts.......maybe not at 8k rpm, but it wasn't as loud as a 107hp d series with a cheap exhaust and muffler............they just sound trashy to me.....ewww....
Old 12-07-05, 08:37 PM
JspecSC3
JspecSC3's Avatar
Yes that is exactly what I mean.
Old 12-07-05, 08:45 PM
JspecSC3
JspecSC3's Avatar
Originally Posted by duckworth
it's not even illegal to put one on as far as i know, the epa will own you if they catch you cutting a GOOD cat off a car to replace it with anything other than an equally effective cat
Your emission laws are different than ours. I live in the state of California where everything is illegal. Muffler shops can only make them but they cannot put it on. Us, the customers have to put them on somewhere else. As far as having no cats goes..If you smog and they catch you without one they will automatically tell you they wont do it. Ive been to a couple shops that have told me that same thing.
The cutting of a GOOD cat is illegal like you said but when getting a test pipe made there is no need to cut anything off. Thats why it is a test pipe. Its just a pipe with flanges welded to the ends so you can bolt it on and off of the stock location. No cutting required.
Old 12-08-05, 07:02 AM
JBrady
JBrady's Avatar
I understand your reasoning but it is the power RANGE that is critical. My engine has a single 55mm/2.18" OD center resonator from the factory and that supports 290hp/300tq. The GS400 with a 60mm/2.37" single center pipe is rated 300hp/310tq. Does this mean that for every 5mm center pipe size increase my engine will gain 10hp/10tq? Unfortunately NO. In fact as the pipe size increases the exhaust speed at any given flow volume decreases. Decreased velocity is a prime reason for loss of low-mid RPM power and responsiveness.
Adding 2.5" pipes to a stock 4.6 liter Ford making 235rwhp/250rwtq is a MUCH different situation than the same on a 4.0 liter Lexus making 175rwhp/185rwtq. That said a properly designed 2.25" system on the Ford would probably make the same or possibly more peak power and make more low-mid power. However marketing is another issue and it is much easier and therefore profitable to sell 2.5" systems than 2.25" systems due to the bigger is better mentality.
The bottom line is you want to use the SMALLEST pipe size that will support your peak power. In some cases smaller actually makes more peak power. This is NOT due to increase backpressure. In fact ANYTIME an engine makes more power due to an exhaust change at WHATEVER rpm there is less backpressure at the exhaust PORT. There are actually many reasons why bigger pipes can actually increase backpressure at the PORT at certain operating speeds/loads. Think about crossover sections be it X, Y or H pipe designs. They universally improve engine response and operating power under the curve. If the bigger is better theory were true you would simply run separate duals of very large pipe size and forget about crossovers. There is a lot more here than meets the eye and peak flow "capacity" is but a small part of the equation.
Old 12-12-05, 07:57 AM
Lexmex
Super Moderator
Lexmex's Avatar
I live in Mexico City with my 99 RX. I have had two precats messed up by low grade gas (gas station said they ran out of Premium) and not another one around for 50 miles plus my 3rd cat got dinged by a rock and was rattling. Had to scrub the precats and put in a Maganflow cat in its place. No CELs to speak of and when I checked at my exhaust shop, my numbers would have been good enough to pass down here.
As I understand it, for your SC in NJ it is only a CEL issue, no tailpipe tests for OBDII.
I had a friend with a RAV4 down here who stripped out all cats (we are at 7,400 elevation and cars runs slow and have bad MPG) and did get a CEL.
A good highflow cat is really what you need, but yeah strip the precats...you won't have a problem.
Old 05-25-16, 03:50 AM
700bones
700bones's Avatar
Hell yeah, do it dog. My brother fitted his with test pipes and got like a 25 hp gain on the dyno.
edhohoho
01-11-17 11:06 PM
readyyrobb
Performance
03-21-16 05:59 PM
xmel012
10-29-13 07:55 AM
hungsmurf
IS F (2008-2014)
04-25-12 03:34 PM
black_gs99
Performance
01-23-07 08:13 AM
Quick Reply: catalytic convert hollowing/removal
