What's missing from this list? (r154 swap)
wait... lets clarify something... i just went over the list again and theres something i don't understand.
it says "any variant of a r154 flywheel".... but then it also says... "if using 7m clutch... 1jz flywheel"
so... mk3 flywheel will NOT work if using a mk3 clutch!??!
not that i know of unless you want to put in more time than neccessary. i have always used 1jz flywheels since the 2j and 1j have everything similar and the 7mgte is completely different from our motors. plus the 1jz flywheel fits inside the bell housing that fits up jz motors and the r154
Originally Posted by ummagawd
okay.... so I need a 1jz flywheel and i can use a mk3 turbo clutch OR 1jz clutch that is correct
here's another one.... what kind of clutch recommendations for a daily driven 450rwhp car?
just make sure its a sprung disc and if its a pucked disc, the more friction points the softer it will engage (aka a 6 puck is softer than a 3 puck). If your a baller, dual disc clutches are nice and soft but take some getting used to when engaging the clutch.
which starters will work with the r154?
i have both a w58 starter from my 2jzge and an auto starter from the 1jzgte
which will work? what alternatives do i have if neither work?
has anyone actually used the mk3 turbo clutch master cylinder and pedal assembly?? theres a guy that local to me that is willing to trade some parts. but i need to be 100% sure that it would work on the sc's. thanks
how do i know if i am actually getting a r154?? is there stampings somewhere??
would the mk3 LSD's bolt up to our cars??
