GE buildup with GTE parts
I'm contemplating whether or not to complete a 2jzgte swap (missing a few things... ) and going single
or just building up the GE block and then going single
My first goal is simply 400-450rwhp. I can't say i'll be happy here cuz we all know what happens when you hit your goal (especially when it comes to HP)..... you end up wanting more.
My car is a daily so i definately will never want 800+ cuz its just not useable.
So now I'm thinking about building up the GE block with GTE parts... i'm trying to find the thread that discussed this very idea along with compression numbers and the right HG to be used for this type of buildup.
I tried searching uner numerous phrases but couldn't turn up anything.
can someone either help me find that thread and or shed the light on the info i need?
RECAP:
what's needed to buildup a GE block using only GTE internals? I know for the sure the pistons... don't remember if the rods were the same..... and what headgasket to use?
and while i'm at it... how much does it usually cost to rebuild a motor?
RECAP:
Originally Posted by JspecSC3
Is that right?? The 2JZGE pistons and rods are forged and are the same as the ones in a 2JZGTE block??? This is very interesting.. ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Originally Posted by VJ RC51
Its the same motor with a different head, why would they produce different parts for the same bottom end?
from what i understand the bottom ends is very similar the only thing that changed in the ge is it does not have oil squiters and the piston are high compression but the rods and crank are the same but the heads are different ,similar but not the exact same good luck with your project
I might be wrong, but i was shown that the GE and GTE pistons are the same also.. the lower compression comes from the GTE's thicker headgasket. Oil squirters are nothing, it doesnt hurt to not have them.
Ya, ive always wondered why people don't talk about this, you can get everything forged and even put in squirters (if you want to drill a hole in your block),maybe even make it a 3.4 liter cheaper than it would be to buy a gte. Then you can mate it up with a getrag and have a pretty amazing car.
Originally Posted by ishot2pac
Ya, ive always wondered why people don't talk about this, you can get everything forged and even put in squirters (if you want to drill a hole in your block),maybe even make it a 3.4 liter cheaper than it would be to buy a gte. Then you can mate it up with a getrag and have a pretty amazing car. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
not sure casue i know in 7mgte and 7mge there pistons are different but the rods and crank are the same also if you look at turbo piston there are grooved in for the lower compression and the the na actually have a lift and non sunk in 1st pic is turbo pistons second pic is non turbo just examples
