trans dont shift until slightly warm??
i have a problem in the morning when i first drive the car that the trans doesnt shift until it gets a little warm. anyone else got this problem?? i would have to warm the car up about 5-10minutes then it would shift normal. any suggestions?
Originally Posted by ATL-SC
normal on the 5speed
or atleast mine does it
old syncros too
old syncros too
Just a guess, but he probably has an auto. My manual shifts fine cold or warm weather though.
sorry for the mistake
I Had/Have the same problem. I don't have the fix yet, but I'm pretty sure it's a fluid problem.
Mine did it much worse right after the rebuild, and I think it may have had air trapped, and the fluid was having a problem traveling until it bleed itself.
Check the fluid level, and maybe a flush.
Mine has gotten better which led me to belive it was air.
Do you have an oil cooler on the trans?
My second theory was that the cooler draining the oil back into the trans pan caused a problem until the pump moved all that extra oil.
FireCode
Performance & Maintenance
17
07-26-20 08:22 AM
scfou
11-02-09 03:43 PM
