twin turbo Soarer GT to SC300 engine swap possibility
#46
I swapped into my SC300 a JDM 2jzgte with no trouble and at very little cost. I bought the car for 5k, the motor and tranny (R154) for $2800 shipped, Supra tt harness for $400, Super-chipped ECU for $350 (used), all stock side-mount intercooler and piping from a Supra for $250. I did all the work myself with the help of Phil's swap manual (BIG help with wiring) in an amount of time that equals 3 full days.
So you see, for about $8800 (not including exhaust and VOLK GTP rims) I have a pretty quick car. I also have a 94 Supra T88 and an IS300 (turbo charging soon), but in all honesty... the SC is my daily driver. For some reason I just like driving it on a daily basis more than I do the other two.
Pics of my SC are kinda crappy, but gives you an idea. DON'T frown at the air intake... my filter hasn't come in yet Also, time to clean up the greasy bay (from greasy hands). It's in there and it RUNS at 17psi making 413rwhp... JDM at that!! I have UR cam gears that you can't see here.
#49
Originally posted by ummagawd
wow... care to share with me where you got the 2jzgte and r154 for 2800 shipped?
also... was your SC originally a 5sp? or did you do the auto->manual conversion?
you can PM me if you prefer
Motor and tranny came in one week!! NOTHING broken.
Call them up because they have things in stock that aren't on their website!
This SC300 was already manual. I had an automatic, but shortly after purchasing that one I found the manual and sold the auto. Nevertheless... I'm now working on one that IS an auto, pedals and hydraulics already installed. NOT A PROBLEM! I have part numbers from Lexus for pedals, lines, etc.
Also, having learned so much from Phil's manual, I've taken on the task of puring over IS300 shop manuals to make the cross references with the Supra. Why?? Take a guess
#50
Originally posted by SoarerJzz3
Hey genyosai, did you buy that prewired harness from turbosc or did you end up doing it your self using Phil's manual?
#53
didya bargain with'em? I checked the site... a 2jzgte is 3500 and they don't mention trannies
Give them a call. Their website hasn't changed even since I bought my motor about 1 year ago
#54
Yeah that is a good price. Did you just buy the long block, tranny from Osaka and get the ecu, harness somewhere else? Was the harness and ecu USDM or JDM?
My ECU is a superchips modified unit, boost-cut removed and rev limiter set to 7,800rpm. I bought that used at supraforums for $350 (great price!). Also bought stock supra intercooler and hoses for a mere $200.00 (supraforums again).
I used the stock flywheel of my SC300 and bought an RPS clutch kit for the MKIII Supra turbo. I had a local machine shop to tap my flywheel so that the MKIII supra clutch set would mount. All about another $330.00. You can use a stock w58 tranny (SC300/MKIV supra non-turbo), keep your stock SC300 flywheel (if a manual) and get a clutch kit for the MKIV supra non-turbo.
OK, ok... so there was a "little" more cost involved, but not much. What's this, another $1,260.00? Sorry
#56
This all sounds really good, if I got a MKIII Supra 1JZGTE Turbo Kit, would it fit well in a 1JZGTE SC300 ? I was thinking of going with the T78 Greddy Turbo kit for the MKIII Supra. It's a nice kit and the fact that the 1JZGTE can rev up is pretty appealing. I do have some questions though:
1. Will the V160(6spd) bolt onto the 1JZGTE or will it be the same predicament of a new driveshaft and all that ? Also, is the R154 built to handle the high RPM that the 1JZ can throw out ?
2. Most 1JZGTE clips I find are 1JZGTE w/ VVTII, where can I find a 1JZGTE 5spd, seems like the manuals are hard to come by.
Thanks for any help, hopefully I can get my 95 5 spd on its way to boosting, thanks.
#58
Any turbo upgrade kit designed for the Supra JZA70 will work for any non-VVTi 1JZ-GTE. As mentioned above, the R154 is the stock transmission mated to the 1JZ-equipped JZZ30. It's also the stock transmission on the Supra JZA70. I've been driving mine for months, and it has no trouble at all with holding the power or slipping, even on a stock Toyota clutch.
-Ray
-Ray
#59
Mortgage Slave
From what I've heard, the R154 tranny is based on a Toyota truck gearbox. It's very strong and can withstand lots of power. There's a Soarer I know of around here that's pulling a tad over 300rwkw using the R154 gearbox, albeit with a new clutch because his old one was gone.
Jose
Jose
#60
Jose
Jose
