SC400 Hydraulic Fan Conversion
Has anyone converted the hydraulic fan on the SC400 to electric fans yet? I'm thinking about doing it but there's one thing that I'm still confusing, and hope that some of you might help me out. It's the ECU cooling fan. It's a separate unit from the engine ECU. However, if I completely disconnect the hydraulic pump and use the shorter belt instead, will the ECU cooling fan do any bad? Or if I still keep the pump on the belt, bridging the hoses, but disconnect the hydraulic fan, will there be any problem with this ECU?
Any info. will be greatly appreciated.
Originally Posted by jssc400
Do You Know If U Cap Off The Lines To The Fan Or What
ok i did it, i converted an sc400 to electric fan and it is working i disconected the oem fan and looped the supply hose to the resavore and did the return to. i buypassed the oil cooler installed flex-a-lite 210 fan's and wired them in just finished today drove about 30 miles and no problem
