DIY - How To: Transmission Mount Change SC300/SC400 5spd or Auto
#76
Whew, solved the above problem after a break and fresh start. There were burrs on the sleeve in the support brace that the 14mm bolt passes through, keeping the one bolt from lining up with the hole no matter how much I tried shifting the brace around. (Easier said than done, being on a bit of a slope which kept the jack from being able to raise the tranny perfectly level.) Once I filed the burrs down slightly, the bolt popped right in. Wish I had tried that two hours and a fair bit of profanity earlier.
#77
acenase
Performance & Maintenance
10-29-07 08:28 PM
