1JZ-GTE Twin Upgrade
Hey guys. Ive searched my *** off on here and I cant find anything so please dont flame. Im looking to see whos gone the route of upgrading the twins on their 1jz rather than going single. I like the idea of retaining my low end to midrange power. Any custom setups...kits....dyno numbers? Id appreciate your help. Thanks.
-Bill
-Bill
I believe there is no such thing as an aftermarket sequential twin turbo system. That means, if you go with aftermarket twins, they'll both always be online. Only way to keep the sequential and have sufficient power are 2jz twins maxed out....
Edit : your other option is to go with a smaller single.
also the turbos from the 2jz wont fit on the 1jz without modifications. I belive starlet turbos will(check planet soarer.com)
some people have made as much as 400+ on the stock twins but those are extreme cases
lastly HKS and Blitz have twin turbo kits for the 1jz.
thats all i have off the top of my head.
So, keeping in mind that we're no mega millionnaire's here, what is an economical way to build a reliable small single turbo system for the 1jz motor that can put 400hp to the ground? Where would you get the parts and how much do you think it would cost?
First, you don't need to be a 'mega-millionare' to build a single turbo, especially if you were budgeted for the 1jz in the first place. After a 1jz, if you want a single turbo upgrade, you can looking up to 5grand. If you're smart with looking for parts and know how to install it yourself, you can save a substantial amount of money.
Second, search.
sae has a custom twin set up on his white SC. he would be the one to talk to.... i think he has had about 3 different set ups over time. personally, i would rather stick with twins over going with a small single. but thats personal preferences. why not just get some steel blades for the ct12s and have them ballanced. they should be able to handle plenty of boost that way.
modify stock turbos
www.turbocity.com does it
Originally Posted by ummagawd
Drop in a set of JDM 2jz-gte 440 injectors and 1.3bar MAP sensor and you're golden for some nice power figures.
my buddy over here has a twin blitz kit, hes got the twin k26s, came with full piping (thank god) and everything. Kit is nice, spools late but pulls hard to end and linear. It looks awesome, but its not very practical, ide give up if i had to make piping for that kit. Plus its more lines, more heat, more chances of failure. If you wanna do it for the hell of it go for it, but if its strictly a performance thing just go big single.
Ang
Ang
I definatly agree with ki_soarer get the metal blades. The ct12a's are just too weak with their ceramic compressor blades. these links are for three consecutive pages in a magazine on how to replace the ct12a's with the metal bladed CT9 turbos form the Starlet. they made 14kW more or about 18.8hp with now bottem end loss and potential for more alot topend with a boost controller.
http://www.users.bigpond.com/pgscott/pdf/CT12a1.pdf
http://www.users.bigpond.com/pgscott/pdf/CT12a2.pdf
http://www.users.bigpond.com/pgscott/pdf/CT12a3.pdf
