would the parts i have work with the r154 swap?
i have the following:
soarer driveshaft
soarer complete lsd rear end
auto 1jz front clip
i want to do the r154 swap before i put the motor into my car. i found a website called driftmotion.com that sells the r154 bellhousing ($350), flywheel ($270), clutch, and tranny ($400). if i was to pick everything up from them would the following parts i have bolt up (drivetrain wise). also do i need the manual ecu and harness or what i already have would work.
also does anyone have any feedback on their intercoolers they are selling? sounds to good to be true.
soarer driveshaft
auto 1jz front clip
you can use an auto ecu w/ a manual car
it will throw a check engine light.
also you have to bypass the Neutral Safety switch to be able to start the car.
if you CAN find the neutral safety switch(want to be safe) it should cost <$10
*edit* noticed that you didn't say who's R154 tranny it was, check VIPs thread if you are getting a supra one. . .
i dont see why you would need any of what you have to change the trans. is the soarer driveshaft you have auto or manual... what about the diff? you may not like an auto diff with a manual trans... just because of the ratios... but you may love it too. if all else fales, ill be willing to buy that diff off of you.
kevro
SC400 / 300 Classifieds
14
08-29-09 04:50 PM
