Help with 1jz wiring
Old 01-19-06, 10:13 PM
minnyminh
minnyminh's Avatar
Default Help with 1jz wiring
Does anyone know what wire harness I need for the SC3 to 1jz swap?
Old 01-19-06, 10:24 PM
ConSynX
ConSynX's Avatar
ohhhh good.
1jz engine, requires a 1jz ecu.
unless you want to have some REAL fun w/ the ecu pin-out use the 1jz harness.
Old 01-20-06, 04:52 AM
Rising_Sun
Rising_Sun's Avatar
Before you get flamed for this post... Please use the search "1JZ" and you'll find more info for your swap than you would ever want to know. But to answer your question. The 1JZ frm a Soarer is a direct plug and play swap. as long as you extend the wire harness 18 inches.
Old 01-20-06, 05:08 AM
Aristo300
Aristo300's Avatar
Hmm... 1JZ engine needs a 1JZ harness to work.
scoarer
03-16-07 07:08 PM
MadMaxxNA
08-09-05 03:50 PM
reamemiya
09-17-03 11:48 AM
Quick Reply: Help with 1jz wiring
