Misfiring help
Misfiring help
I am pulling my hair out trying to figure out what is wrong with my car and was wondering if you could help me out.
About a week ago the car started acting like it was missing, I figured that I had gotten some bad gas or what not. Week went by and it only got worse. It has a really lumpy idle and jerks and sputters below 2k. If you unhook any of the plug wires at the distributor it does not change the idle, if you plug it back in the idle smoothes out and the car runs good for a little bit.
I have changed the following.
Plugs
Wires
Rotor
Distributor
Ignitor
Coil
and one of the O2 sensors.
If you could point me in a direction of what to look at I would be very thankful.
Car is a 92 Sc300 5spd if it helps.
Plugs
Wires
Rotor
Distributor
Ignitor
Coil
Mine i doing the same thing right now but its because i power washed it,It was not starting at all but i got the water out from between the plugs and i finally got it to start.I kept it running for a while to make some heat to evaporate the rest of the H2O out.
