View Poll Results: Will Supra Auto TT LSD work in sc300 rear pumpkin w/ stock ring gear & pinion shaft?
Yes
90.53%
No
9.47%
Voters: 95. You may not vote on this poll
Supra Auto TT LSD Install in sc300 pumpkin?
Old 02-14-07, 08:34 PM
Da Coupe
Da Coupe's Avatar
Did you still use your stock sc ring gear & pinion?
Old 02-14-07, 10:10 PM
dejacky
dejacky's Avatar
Yes, the stock oem SC300 ring gear and pinion shaft were re-used, thereby retaining same final drive ratio as a stock sc300 .
Old 02-15-07, 06:25 PM
Da Coupe
Da Coupe's Avatar
Perfect . Thanks
Old 05-05-07, 12:35 PM
1badsoarer
1badsoarer's Avatar
I put an entire supra TT auto diff in my soarer. The only thing i had to do was swap the yolks. The supra yolk and the soarer driveshaft holes were off a few MM. The 3.26 gears are nice...
Old 05-05-07, 01:44 PM
TTSC3
TTSC3's Avatar
I had started a thread about LSD's a few days ago, but I was wondering if anyone had any thoughts on using a MK4 TT LSD, vs buying a Kaaz LSD that's actually FOR an SC300? Is there any benefits to doing either besides the fact the Kaaz costs a bit more?
Old 05-05-07, 04:11 PM
96sc300tt
96sc300tt's Avatar
woot woot lsd! i want one too. i hate the loosey goosey when 2nd gear hits.
Old 05-05-07, 07:46 PM
SCoupe
SCoupe's Avatar
Originally Posted by TTSC3
...using a MK4 TT LSD, vs buying a Kaaz LSD that's actually FOR an SC300? Is there any benefits to doing either besides the fact the Kaaz costs a bit more?
I thought the Kaaz are about $900 and the eom MKIV TT LSD is in the range of $1,700. I'm talking new here. Are you comparing used MKIV lsd to a new Kaaz?
Old 05-05-07, 10:59 PM
TTSC3
TTSC3's Avatar
Yes, I'm talking used vs new Kaaz. I would never spend that kind of money on a new TT diff, but that's just me. I just wanted to hear why one would choose one over the other, besides money, and the Kaaz 2-way being a bit louder in a parking lot.
Old 05-06-07, 05:21 AM
1badsoarer
1badsoarer's Avatar
Well I drag/drift my soarer with a TT supra diff, and it does it's job day in and day out. I've hit 270km/h (or so) I ran 7.10 in the 1/8 and I can drift it. Not to mention I got the supra diff for $42.
+1 for supra diff
Old 05-11-07, 09:06 AM
96sc300tt
96sc300tt's Avatar
doesnt the soarer already have stock lsd? ^---- or did you just want the different gears? need to know asap about to buy a soarer rear diff thinking it does have lsd.
Old 05-11-07, 10:50 AM
1badsoarer
1badsoarer's Avatar
Im not sure what kind of diff the soarers have stock, but I know it was a useless 1 wheel wonder diff in my soarer.
Old 05-11-07, 11:10 AM
96sc300tt
96sc300tt's Avatar
hmm, they are going to double check for me, thanks for the quick reply
Old 06-26-07, 07:31 PM
Blizzy
Blizzy's Avatar
this thread is a thing of beauty. I am glad this resurfaced. I will be using this as a guide for sure when I drop in my LSD.
Old 06-26-07, 08:32 PM
TheMole
TheMole's Avatar
Good stuff here! I know that the MKIV n/a lsd will bolt in and keep the same gear ratios, but will the TT auto lsd change the ratios?
Old 06-26-07, 08:50 PM
JspecSC3
JspecSC3's Avatar
Originally Posted by dejacky
Supra twin turbo automatic torsen limited slip differential has been installed into my Lexus SC300 Rear differential housing. Everything feels butter smooth and the car is so much more stable when turning and braking now, it feels much safer and predictable to drive. When I accelerate or go WOT (wide open throttle), the car now goes straight instead of toqueing to the side and making the rear-end squirley.
There you have it folks! It works. There has been some confusion on this subject for quite a while. Great Job Dejacky. Now I know what else to add to my list of Mods.
Quick Reply: Supra Auto TT LSD Install in sc300 pumpkin?
