View Poll Results: Will Supra Auto TT LSD work in sc300 rear pumpkin w/ stock ring gear & pinion shaft?
Yes
90.53%
No
9.47%
Voters: 95. You may not vote on this poll
Supra Auto TT LSD Install in sc300 pumpkin?
Old 04-29-09, 06:18 PM
  #46
nate579
nate579's Avatar
Just purchased mine at MVP motorsports. Fast delivery, less than 5 days. Paid $958 + $158 for installation kit. New Seals, Bearing and Sealant. $35 for shipping, very impressed with the service. I think they are Vendors here but for sure on Supra Forum.
Part # 41301-JS402 for Auto TT LSD and LSD Install Kit(PTR04-00026). Hope this helps.
Old 04-29-09, 09:07 PM
  #47
dejacky
dejacky's Avatar
Question
Nate,
thanks for the part number and pricing info. I'm just curious, why didn't you get the TRD clutch-type lsd for a similar price?
Old 04-29-09, 10:05 PM
  #48
SC300_NW
SC300_NW's Avatar
This is awesome info... thank you so much!
Old 04-30-09, 05:55 AM
  #49
nate579
nate579's Avatar
Originally Posted by dejacky
Nate,
According to TRD and MVP this is a clutch/Mech. Plus it's 1.5 or 2 way selectable. Here's the write up from TRD:
The TRD mechanical LSD is 1.5-way selective, and can optionally be switched over to a 2-way without any additional parts. (It can only be 1.5-way on Vitz models and 2-way on FR vehicles.)
With the 1.5-way, the LSD functions most during acceleration, and is weaker when not accelerating. (The 1.5-way is designed for novices, since vehicle control becomes more difficult when the engine is used to brake.)
With the 2-way, the LSD functions when not accelerating as well, providing excellent vehicle control under a variety of conditions.
■ Because the limited slip capacity is provided using a number of clutch plates, it exhibits a direct, reliable LSD effect.
Most Supra owners uses the TRD over other brands,due to ease of install and power handling capabilities (800+ Hp), not to say there maybe better brands out there ie, Cusco. But I don't need or want 2-Way LSD, due to drivabality.
Old 04-30-09, 06:18 AM
  #50
nate579
nate579's Avatar
Oh I forgot, make sure you purchase from Toyota the 10 carrier ring bolts. The originals ones that are removed cannot be reused, due to stretching. The torque specification are quite high when installing them. Prt # 90105-12219.
Old 04-30-09, 12:27 PM
  #51
tonysc400
tonysc400's Avatar
is a sc400 rear end LSD? i have a 2jzgte swap and not sure if my car has a supra rear or a stock sc400 rear end?
Old 04-30-09, 07:22 PM
  #52
nate579
nate579's Avatar
Nope it's Open DIff, but from my understanding, TRD LSD Auto will fit SC300/400, there are few 400 on the forum running them, do a search to find out who and you can pm them for more specific information.
Old 05-01-09, 01:30 PM
  #53
Sc300drive
Sc300drive's Avatar
ok so is the rear end from a tt supra the same rear end on the sc300?
Old 05-01-09, 11:35 PM
  #54
wanganstyl
wanganstyl's Avatar
basically, this is how it works.
there are 6mt cars, 5mt cars and 4eat/5eat (automatic) cars
the 6mt car has a special diff. only car with 6mt is mk4 tt 6mt
4eat and 5mt cars have identical lego parts diffs- gearing may be differnt, but all parts are interchangable
MK4 TT was avail in 4eat or 6mt. the 4eat had an OEM LSD. that LSD will Plug and play into all LS400, GS300/300, SC300/400, and MK4 supra TT and NA - the only thing it does not work with is the 6mt supra.
so all toyota LS400, GS300/300, SC300/400, and MK4 supra TT and NA is same, unless 6mt.
if you have a 6mt car, you need 6mt lsd. if you have 5mt or 4eat car, you need "auto tt LSD or TRD LSD for auto TT mk4 supra.
  #55
wanganstyl
wanganstyl's Avatar
Old 05-02-09, 08:21 AM
  #56
nate579
nate579's Avatar
Amen brother, I knew it was something like that. That should clear up all the LSD questions regarding fit.
Old 05-02-09, 12:14 PM
  #57
Sc300drive
Sc300drive's Avatar
ok bro thx alot that was a big help!
Old 01-07-10, 02:03 PM
  #58
IS300SS
IS300SS's Avatar
thanks for this!
Old 03-26-10, 05:29 AM
  #59
fastegg
fastegg's Avatar
Default LS400 torsen unit
Originally Posted by UpInTheLex
Yes It should work fine.
Attention to detail is needed on the setup of the differential. Good luck.
hi... would this torsen unit fit my 1998 LS400 ?
Old 03-26-10, 05:34 AM
  #60
fastegg
fastegg's Avatar
hi... what does 6mt, 5mt and 4eat mean ? i have a 1998 LS400 and are looking for LSD solution...
Quick Reply: Supra Auto TT LSD Install in sc300 pumpkin?
