So your door handle doesnt work - DIY w/ pics
#241
Does anyone have a good picture of the rod that's SUPPOSED to be inside the door? my passenger door is missing it entirely when I tried fixing the handle a year or 2 ago. Is it possible to "rig" a coat hanger or other fabrication just to make it work? I dont have 400$ for the lock assembly from the Lexus dealership. (there are no junk yards in the area with my car)
#242
You might be able to fix it with a self-made rod, but unless you're good at it and do it perfect, I suspect you’ll just end up creating something that you’ll have to go back in and keep fixing. If the rod isn’t lined up just right, it’s going to get stressed every time you open the door, and it won’t take long before it snaps again. Been there. In the long run, you’d be better off just replacing the assembly.
Search Ebay for one. I one for about $110, and there were several for sale. You might be able to find one cheaper, but that's the best I found when I was in need, which was only about 6 weeks ago.
You do NOT need the painted door handle assembly; you only need the locking assembly that actually keeps the door closed.
#243
Like a few others, I had my window down when the problem occurred and didn't know it till the damage was done. My door is shut and won't open from either handle and I'm not sure how to get it open. I tried the window trick while pulling on the handle (apparently I didn't pray enough while doing it), and someone said to take the screw behind the handle out as well as the arm rest screws and shove your hand down in there, but I don't see anywhere where you can access the inside of the door from there. Any help would be greatly appreciated. I've got black interior, so I'd hate to ruin it by having to cut...
#244
I have a 92 sc400. My driver side door "snap" clip broke. 1 reply said number 69293-12040 but i look it up and my model number is not in the list.
Does anyone know were i can get one. Lexus dealer wont sell me the "snap" I have to by the handle to get the "snap".
#245
a temp fix to the problem
I dont know how long it will last. but i open and shut the door 15 times with no problem.
I used a 5/64"x1-9/16" hair pin. I put the rod threw the hole of the handle and put the pin over the notch of the rod.
I will post if it ever breaks again. But I still would like to find a back up snap for it.
#246
Muttduck, you can get the clip from a Toyota dealer for less than $5. The clips for the left and right doors are different so you'll need to have the right number which you can find by searching this forum.
#247
Great thread. Did this today and took about hour and half (spent a good half hour trying to ram rod + clip into the hole to no avail).
As others have stated (and I should have checked before doing it), put clip into hole first then insert the rod. Much much easier.
Spent under $4 at the local yota dealership for the pat.
#248
Advice to anyone who can't find their rod, or believe it has disappeared......pull the front speaker and feel around. That's where I found mine. The fork part is broken, but the rod had worked it's way up to the front of the door. Hope this helps.
Jim
Jim
#249
yes, im not the only one that lost it here! also i made clip out of a zip tie lol
#250
Passenger side door DIY
Much respect to my new Lexus Family for the info, just bought a salvaged 1995 SC400 and the passenger side door wont open from the outside inside only til last nite when my boy broke the inside door handle.
Im going to order the parts so i can use the passenger side door
Thanks,
Hotep.
Thanks,
Hotep.
#254
Interior window/door wont work
Okay, I took my 95'SC400 to my repair guy shop to repair my pass.exterior door to open.
He took off the panel saw that the little piece was off, went to his tool drawer got the piece (snap connector) hooked it up in 5 minutes exterior door opens from the outside but still not from the inside and the window wont roll down now, help whats the next step?
Hes talking about $80 to take the metal panel off like 4 bolts.
#255
Windshield fogs up
When i have my heater *** off in the morning on my way to work my windshield doesn't fog up.
When it gets cold outside i want a little heat inside so as soon as i turn the **** to the right the
windshield starts to fog up from the bottom up, then i have to turn my heater AC on waste gas
yadda yadda yadda whats the problem and how/what can i do to fix this problem?
